My new Fairphone3 is designed to charge with a version QC 3.0 compatible charger with Output: 5.0V ๐ 3.0A/9.0V ๐ 2.0A/12.0V ๐ 1.5A 18.0W MAX.
I have a 65W laptop charger Output: 20V๐ 3.25A/15V ๐ 3.0A/9.0V ๐ 2.0A/5V ๐ 2A. Is it safe to use it?
(the laptop charger is the only charger I have with USB-C)
Looks like a match. 9x2=18W
The laptop charger likely uses the USB PD protocol instead of QC 3.0, meaning it wonโt do 9V but should charge at 5V. Itโs safe to connect it.
Pretty surprising for me finding this post about someone else using his mobile computerโs power supply for his mobile having USB-C.
Yes, sure USB-C had a bad start with many incompatibilities and devices busting into flames or at least melting power sockets frying devices. Things got a bit better meanwhile.
The initial idea of USB-C was to even have a higher universality and compatibility than with ยตUSB. But there are always scammers simply gluing together some left over parts and selling them. Some of them even come from Asia
If itโs not from the Fruit company but from another manufacturer caring about broadly more common official standards itโs absolutely save to use an available โcertifiedโ USB-C charger for whatever device having the same socket type.
If itโs for home use surely any proper charger (speaking of fixed cables like for notebooks) should work fine unless one manufacturer did not care about the official standard.
Itโs different with cordless chargers as the cable also can make a difference if charging will work properly or not.
I will also start off with my 65 watts Lenovo psu for my FP4.
Somehow the wrong logic persists among many users believing that a charging unit listed with a higher current value will blow a connected device. According to electrical rules and physical laws, generally spoken - itโs the voltage pushing current through any device. Current it the consequence of voltage. No current without voltage (neglecting L | C elements). Usually itโs the voltage that has to match, not the current.
If there is more intelligence involved like in USB-C thereโs some type of negotiation between the charger and the end device. If thereโs no proper negotiation achieved the lowest or no charging level will be established. Of course this process only works securely if both partners (+ cable) are based on standardized designs.
Apple chargers tend to be compatible with devices of other brands nowadays so I donโt expect much trouble.
Itโs a USB PD charger, so likely no โfast chargingโ on the FP3 as it doesnโt support this protocol, but normal charging should work (at most 5V * 2.4A = 12W; the phone will refuse to draw more power if there is no QuickCharge-compatible charger detected.)
It looks like the FP4 might support USB PD, allowing fast charging from a laptop charger.
