Perhaps I should explain my idea a little more clearly: The battery disconnect (kill) switch should only work when the phone is already turned off. Then there can be no system crash.
I mean the arguments you make are so poor I am almost convinced you work for a three letter agency and intentionally dump on privacy features.
“If you’re worried about your privacy, then don’t buy a smart phone.”
That’s not how the world works. Many people are required to own a smart phone for work for example. Do not give people false choices.
“Switching off a part of that device because you’re not using it at that point won’t protect you from governments or ad companies. It will give a false sense of protection.“
Uhm yes it will, that’s the whole point.
“If you can’t trust the software on your phone, then don’t use it.“
Jesus the whole point of hardware switches is that then you don’t NEED to trust the software. Is this really this hard? It’s not simply about someone monitoring the websites you use or what apps you visit. It’s about who can follow your activities even when you don’t use your phone and it’s in your pocket. For those moments it is extremely vital for a privacy-conscious person to be able to physically disconnect camera, mic, GPS etc. I am scratching my head whether your comment is trolling or you are an undercover agent spreading intentional bullsh*t.
At which moments would you use this kill switch? And taking into account tracking and profiling, when will you disable the switch? Please give me an example over the timespan of a month. Why a month? Because I think you are thinking short term, while tracking and profiling requires long term data for it to become accurate. Of course you are going to use your phone as a phone long enough to allow tracking/profiling.
Once you start to use your smartphone as a smartphone, only a few data points are needed to build up a profile for ads.
So the bottom line is that you need to be able to trust the software. Because of course you are going to sync your email, login in apps and websites, navigate through town with GPS with your home as destination or starting position, do online banking, share pictures, connect to WiFi networks, connect to cell towers, etc.
You honestly think that in those moments you don’t need these services and turn off certain aspects of your phone, you can create gaps in profiling/tracking that will confuse government and ad companies?
Also, you’re cherry picking my initial comment. Please read it again, I make good arguments why a kill switch is just giving people a false sense of privacy.
I have a very bad news for you : it is possible to follow you even if you don’t have a smartphone using WiFi around you ( Your body can be fingerprinted and tracked by Wi-Fi signals | PCWorld).
Kill switch or not will change nothing in this case.
Personally I would use all kill switches the moment I put it from my hand to my pocket. If I need GPS tracking for navigation, of course I need to turn it back on. If I need to call someone, of course I turn it back on. One part that makes modern smartphones so damn addictive is that they are almost never truly off, even when you want them to be. I have bought a Faraday bag as an experiment for my smart phone to see what it feels to be truly offline. This experiment has been honestly quite shockingly healthy for myself. I would use the kill switches like I use my Faraday bag. With the added benefit that it would be an in-built “Faraday bag”. You talk about software but hacking a software system is not something you would necessary notice, so you have to think of the average person who does not have time to read through their phones source code. Hardware kill switches are intuitive in how they work, unlike complicated software. And no matter how sophisticated the software is, it could still be hacked and the user may never know about it leaving them guessing. Hardware switches cannot be remotely hacked. They are either on or off.
Even if this is possible, it still does not render kill switches irrelevant. You carry your phone everywhere. But you can walk out a building.
Tell me, when exactly would you do use it? At home? At work? While commuting? When going out? I think you get my point. These are data points and profiling works just fine with this.
Moderation can be done with self discipline. You don’t need a Faraday cage for that. Or kill switches.
I just explained when I would use the switches. Whenever it isn’t actively in my hand. If the question was inversely when do I use my phone then. Strictly when I need it, I text someone, I check email, when I need maps fro directions. My screen time is consistently 2-3 hours a day. I would rather have a big brother on my shoulder 3 hours a day than 24 hours a day. If I need to search something truly sensitive, I have other methods and devices for that.
About phone addiction, phones are incredibly addictive because they are never truly off. Kill switches basically lobotomize your phone on the hardware level and I’ve noticed doing that same thing with Faraday bag is very useful for focus. Self disclipne is a finite resource, why use it to something that can be solved by good engineering instead? You can’t tell true phone addicts to just use self disclipne alone, just like you can’t tell alcoholics to use self disclipne alone to stop drinking.
So like I said, the bottom line is that you need to trust your software. What you describe won’t stop ad companies or governments. So it is a false sense of control.
About phone addiction. You can put all kinds of barriers there, but in the end discipline is what keeps those barriers in place. Unless someone else has to unlock your phone. Managing notifications is easy with all the built-in features. But then again, self discipline is what leaves Focus Mode/Do Not Disturb enabled.
A kill switch is a gimmick. I hope Fairphone will never develop one because it will mean resources will be allocated to it while the goal of a kill switch won’t be realized for anyone.
Trust me its must better for over all wellbeing and mental health that you have the concrete option to make your phone a brick. Not only for privacy but downtime as well. Personal devices were never supposed to be this surveillance agencies wet dream. They crept that way because of moral laziness by the manufacturers.
About phone addiction at the end its not about self disclipne, it’s about friction. Two totally different things. There are tools like techlockdown.com that are designed to let users apply a desired amount of friction to their digital habits. Friction to use restricted features does the heavy lifting, self disclipne is needed to place that friction there in the first place.
To address the fact that you still need to sometimes toggle the kill switches to actually use the phone. Guess what, that’s still a great amount of control in the hands of the user. A lot of people unconsciously think about these things already. “Should I search the internet for this”. “What if someone is lurking my cameras or mic”. People consider these things already and let it subconsciously affect their behavior. This goes more to behavioral psychology than purely technical phone features but they tie together strongly.
I would rather have a device that when I connect with it to actually use it, I am conscious what I do with it and I don’t mind being surveilled. But when I put it down, I want to know that whatever sensors the phone has, I am not being tracked while I’m not using it. That has nothing to do with software trust. That has to do with physically disabling every sensor of my phone when it is passively sitting in my pocket.
More and more cities offer WiFi for free in their streets…
But it’s not a thing to protect you from tracking or profiling. Like I said, think long term. With enough data points these profiles are established nonetheless. It all comes down to the software in the end. It’s a useless feature that gives a false sense of control and privacy.
I still don’t understand what you are aiming at? That practising privacy disclipne with your devices is futile because governments love other ways to surveil you too?
I would love to see a precedent set where any sort of criminal conviction for example for political activism is decided based on WiFi tracking. I’m waiting.
What I know is that personal device tracking is used consistenly by law enforcement to track citizens who delude themselves that they are free.
You know the New shift phone? A german company paying good wages in their factories and habe a good repairability. So maybe thats a phone fitting your needs.
I don’t see the point to continue the discussion ( but I do ) since :
- There are many ways to follow you even without a phone like cameras in streets.
- Fairphone uses Android which is not the best software if you want to go unknown and people don’t want an alternative for it (fairphone already tried and the number of people using Murena is small compared with the ones using Android).
- There are phones with kill switch for people like you convinced that this is the panacea to protect them.
If I think about the countries where fairphone sells, I don’t think political activism can send you into jail. If you have a counterexample, I would be happy to know it. Then maybe it will help us to understand why you want a kill switch.
No-one needs to understand why someone wants a kill switch, so yes, the discussion is none its just repetition to try to convince the other party. What about agreeing to not agree as everything was said?
Yeah, it’s kinda a non-discussion. When people don’t want to be tracked, don’t carry a mobile device. Also, the device already has a great kill switch… off. Nothing less would be enough to not be tracked via the device anyway, the moment a phone connects to a gsm antenna it can be tracked.
The world is already infested with devices to track people that even without a mobile device people can be tracked with all doorbel cams, security cameras,… but it’s a lot harder.
I don’t think you understand what I mean. Or then you have some revolutionary insight into profiling that I don’t have. If I use my phone online 2-3 hours a day and the rest of the day the phone is totally clueless to my behavior that is an order of magnitude privacy improvement compared to how most people use their phones today.
None of the external surveillance methods are quite like mobile phones, you are literally carrying a 24/7 location tag if you have any smart phone with you. Governments have surveilled us long before any digital devices, and now you say give up completely because these other ways exist. At least external cameras give you a chance. You have to have a sinister amount of them to mass surveil people with them. And we have seen in countries where they go too far with security cameras, people vandalize them. Yet for some reason people don’t see a problem with a smart phone.
I never claimed kill switch was a panacea. I said from an engineering challenge point of view it’s a no-brainer and it would happen if there was public demand for it. Here is my two cents for public demand so that fair phone team understands the arguments for it.
