Is there a way to disable every light notification?
They are simply useless to me
I notice that nobody has answered this, so I thought it was worth responding to bump it back up in the list of recently updated topics.
There are some apps that allow you to control the notification LED, however I’m not sure if there is one to disable it completely - you’d probably have to have a look through apps on the play store unless anyone has any particular recommendations.
For me the notification LED is useful as it allows me to know when I have something to deal with like when I’m working, without having to keep switching the phone on to look at the display. It all depends what you’re used to and how you want to use it
