The website article about the refurbished FP6 contains a very interesting (and worrying) clause (I have bolded a concerning part)
Please Note: The internal specifications of a new and refurbished Fairphone (Gen. 6) are completely identical, with one minor exception: because refurbished phones may have been opened during tech checks, the original IP (ingress protection) water-resistance rating cannot be guaranteed.
I have always assumed that Fairphone IP rating is lower due to its modularity. That is why I followed the development of Shiftphone 8 with their promise of delivering a higher IP rating - they kinda promised higher, ended with IP66 and had a special article* outlining the challenges
In our laboratory tests, the SHIFTphone 8 successfully met the requirements of the IP67 protection rating. However, this enhanced protection only applies under certain conditions:
- The device is fitted with one of our custom-fit bumpers,
a newly fitted, nano-coated display is installed,
and the device has not yet been opened or taken apart for repair.
Shiftphone further explains
As the IP67 protection rating would only be guaranteed under certain conditions, and we don’t want to raise false expectations, we have deliberately chosen to market the SHIFTphone 8 as a water-resistant device with IP66 certification. (…)
but also notes (again bolding mine)
The SHIFTphone 8 is equipped with optimal water protection as supplied. However, this protection may be compromised if the device is opened. If, for example, the sealing lips are positioned incorrectly, screws are not tightened properly or the display is not fitted precisely during reassembly, the original water protection can no longer be guaranteed.
Despite the SHIFTphone 8’s good water protection and the certifications it has achieved, damage to the device caused by water or other liquids is excluded from the warranty.
(*) The article is in German, my understanding and quotations are then DeepL based.
I tried to dig deeper and compare with other non-modular phones. I was not able to find anything conclusive. Some customer forums have had questions on battery-replacement impact on IP rating and reassuring answers that if repair is done in an authorised centre, IP rating is maintained. Plus one fixit reply that it cannot be guaranteed and no service does it ![]()
The fairphone website on IP rating does not mention anything on the issue of opening the phone and affecting the IP rating, instead we can read
It makes us very proud to get an IP certification while respecting the right to repair and allowing our customers to fix their phones by themselves.
All of that makes me upset that refurbished fairphone devices - checked and reassembled by professional technicians are to have lowered IP ratings.
This post was edited and moved to create a new topic. Apologies for the wall of text (the weakness of a researcher), TLDR version below
TLDR: refurbished FP6 devices have allegedly lower IP rating due to them being opened (sic!)
