Install /e/OS with working data cable?
Hello everybody,
I try to install e/OS on my FPH4.
So before i started i got a question,becouse in the description is written
i had to use a working data cables???
Make sure you have a working data cable to connect your device to the PC. There are cables which are only for charging and do not transfer data.
The cable that i use is possibility to transfer data i guess.
so how can i see the difference and i thougt it maiht be transfer data for installing the new software?
sorry i m a bit confused about that may by there is somone how can help me?
thanks a lot,
Welcome to the Fairphone Community! :slight_smile:
Connect your FP4 to your computer. Swipe down from the top of the screen to see the white notification at the bottom and tap on it:
Now if your cable can transfer data, you should be able to choose “File Transfer” here:
If this option is not available, the cable might not be able to transfer data.
Hello urs-lesse,
Thank u alot,
i try it,
