My phone is gone,and i don´t have my IMEI saved. Were can i find it elsewhere. i cant use the support without the number(crazy)??
If you still have the package of your FP3, you can find the IMEIs there.
What do you mean with ‘gone’? Was it stolen? Did you loose it? Did you send it to the manufacturer for repair? Or doesn’t it start?
If You still have it, you can find the IMEIs in the battery compartment.
“on your invoice or delivery note” > FP3(+). IMEI & Serial numbers of your Fairphone and modules – Support
Best wishes,
Thomas
Hallo,
i lost it.
And the box is gone.
So i can´t get a new simcard from Halebop without the IMEI number.
Best regards Catarina
