First up neither am I experienced with smartphones nor am I a computer geek so please have mercy
I followed this guide to install Sailfish OS on my Fairphone. I did everything until step 3. Then entered the command āfastboot flash userdata userdata.imgā and it said thereās an error. Something along the lines of āsending sparse userdate failureā. Since then the only thing I see on my phone is the Fairphone logo.
I can not turn the phone off
It does not respond to anything. (Holding the power button reboots)
The device doesnāt show up on my computer
I hope you guys can help me. Iām completely desperate to get it to run again.
Can you boot into recovery? (Is there one with sailfish OS?) an do a factory reset?
You can enter it by pressing on and vol down or up, have to look it up, I forgot which one. The other one goes into fastbootā¦
I think you can still access fastboot mode by pressing VOLUME DOWN + POWER BUTTON combination. At least, the description of the āFairphone logo screen that canāt be shut downā matches the fastboot mode, for me.
If thatās the case, your phone has a great possibility to be restored by following the steps for flashing the original flashable images for Fairphone 2 images here (advanced users section). Be sure to download the right file, ending with -img.zip, not any other (nor -ota.zip ended files)
