I there I need a fairphone 1 battery. I have used my fairphone 1 since 3 years and I am fine with it. I don’t want to lay it by side just because of the battery. At the moment I need to load it 2 times a day. I am very sad about that. Is there anyone who have a second battery for me?
Thanks for the hint. I first wanted to try to get an original one, because I am not that good in electronic stuff and scared, that I am not able to make that spacer fix thing.
Well, I just take some cardboard and fold it a few times, so it fits the freee space sitting tight and applying some pressure on the battery.
That’s low-cost, sufficient and - at least in my opinion - safe. Should the phone be getting hot enough to light up the cardboard, it will surely have “burnt” throug your pocket first.
How does the spacer work for you?
Do they still sell this orange silicone-part?
I ordered just the spacer and it was way to flexible in my case. Whenever the phone got a light bump, the battery lost contact and the phone went off.
That’s why I returned to some cardboard folded up and pressed in, to keep the battery tight in place.
Hey I have the Battery and the spacer now. Mine was to small to. Yes they still sell the orange one. I just put some folded paper next to the spacer and now it works. I am very happy, that it works now!
