Hi, I don’t receive the calls anymore… but I receive the SMS. I have to reset my phone when I have to call somebody even it’s doesn’t work and after one or two minutes, the call cuts!
The triangle of phone network skip all the times
I changed my SIM but it’s worst…
Someone can help me?
Well, actually that doesn’t sound very good.
You might try a factory reset (after doing a backup of all your data) to see if that helps.
If not it sounds a bit like a broken (or disconnected) antenna.
EDIT: I’ve just seen your french topic and your question regarding repairing the antenna… Well, there are several topics about that here in the forum…:
https://forum.fairphone.com/search?q=antenna%20category:49
Thanks ! I will look that !!
