How “waterproof” is the FP3? IP Rating
Sounds exactly like my story aswell, so it’s not a ‘single cause’
I really feel for you, and I’m sorry to get your stories down to stats, but 2 stories, or even 5 stories out of… I don’t know how many, but certainly quite a few, is what I call a near “single cause”. There is also a story of a user whose FP3 fell in a lake, stayed here for the night and had nothing and was perfectly working (saw it somewhere, then believe it or not), there are extremes on both sides, they had good luck and you probably had bad luck. I don’t say it’s impossible that it’s a problem with the phone, and it’s perhaps a defect, but please remember the FP3 was never marketed as waterproof and only has an IP54 rating, which under heavy rain isn’t much.
I can also tell my story with my FP2, which I once had in my pocket during a quite heavy rain, thinking my pocket was waterproof. Though I know how stupidly you can get water damage, and when I opened it I found drops of water everywhere. Opened it, let it dry, and had no problem after. Had I not checked… :man_shrugging:
TL;DR Two stories are not much, even more on an unrepresentative online forum, only stats can tell if it’s a design fault.
The problem is: Every device has its history, and if bought second hand, nobody knows until every part is disassembled…
Sure :slight_smile: Well it’s in a couple of tests and reports aswell (unfortunately I’ve read them now and not before buying it). But this is still a very important point (and I think I’m not just talking for our three or four cases). The typical FP costumer does willingly accept deductions on the technical status, the weight, the size, price etc. but wants it to be longlasting and best possible for the enviroment and people.
This is why I’m dissapointed, because it was just those two little things that where imporant for me and now it’s more vulnerable than everything I’ve ever had. And I think it should be more visible if there got dampness in there as it took me a lot of time to explain, check, try, reset, send it in (and my spare phone is so old, that it has a grey beard and a walking stick (;)), so it’s not fun to wait for the other one to come back without anything changed)
like me but no walking stick yet, thankfully, I get by and about. :slight_smile:
I agree with everything but
wouldn’t that be nice but age tells there’s no should, maybe could, but definitely a hope for the future.
Yes, but the problem is: Dampness (water) is the greatest evil of electronics. Once the corrosion has started, there is no way back, and such devices can then no longer be sold or with great difficulty only. But it might turn out that your device is not severely damaged, because the watermarks may turn red quite easily.
My advice: Take back your phone and look for another (used) camera, and see how long both of them are going to last. And do not forget to make backups regularly!
:point_right: :pencil2: List of people selling or giving away their FP3 camera modules
Just a simple idea on the side: As I now have a couple of the little plastic bags that new FP2 slim cases come in, I have gone to use those bags as an emergency rain protection for my FP3+.
These little simple bags come without holes (previously I found many little plastic bags from other products I kept had punched holes out of the box – maybe a precaution against suffocation of kids?), they have a sealing line (one of those you press shut) and while they certainly won’t seal enough to go diving with your FP3 (or FP2), they still come really handy when you just want to protect your device in your jacket when you get into rain unexpectedly. With some care, you can even just fit an FP3 with a protective case inside them.
Having a case also helps keep some water out. :slight_smile:
@fellowfreaksnnerds: I tested it. I filled some instant lemon tea corns (granulat, you might remember from waaaaay back … :wink: ) into the bag, tried to push out as much air as possible, made sure the brown stuff rested right next to the sealing line and submerged it under water for 2+ hours. See what it looked like then (first photo still fully submerged after 2+ hours, the other two after wiping the bag from outside):
Not too bad for a bag not designed for this. Please note the sandy parts near to the sealing line were already that sandy when I filled the stuff inside. It does seem that tiniest amounts of water were able to enter at least at the very left, but frankly the wiping and dealing with the bag after pulling it out of the water might have done it just as well.
What could be helpful to future readers of this thread is:
Is there a way to check the moisture sensors yourself, and if so how? So that if they are activated, there’s no use sending the phone for repair.
They can be checked by dismantling the phone and looking to see if the rather obscure white dots have gone pink or red.
Maybe the two little white squares one top left, the other centre right.
n6YBHoWVNpR6taKK.medium
Yes indeed, I can assess of a water damaged FP3 I dismantled with these two square indicators red.
On the contrary of the FP2, there doesn’t seem to be any indicators on the modules themselves, neither inside the modules (or I haven’t found them).
Also, if you see white traces of corrosion inside the phone, on the metal plate, on the connections, I think you can be quite sure this will also be treated as water damage, even if the water, for some reason, didn’t reach the indicators.
Here is another image: My daughter dropped her phone in the toilet. It was only in the water for a couple of seconds. After drying for a couple of days it has been working for 7 months since.
However as I now have the phone I’ve dismantled it as i am inquisitive.
Here is an image showing the bottom module and a ‘red’ square
IP Ratings are only good when they come out of the factory, and there are not permanent.
IP67 Rating vs. IP68 Rating Differences
The differences between IP67 Rating vs. IP68 Rating enclosures are:
  • An IP67 enclosure is rated to be protected from immersion, but only at a depth of 1 meter and for 30 minutes.
  • An IP68 enclosure is rated to be protected from immersion of at least 1 meter and up to 30 minutes (This could also be extended if specified by the manufacturer).
Hi and welcome to the forum.
I think your efforts are a bit misplaced :slight_smile: The FP3 has no IP rating. Even the FP4 only has an IP54
But for those interested ‘ratings’ see
https://www.iec.ch/ip-ratings
