I accidentally swiped on ‘hide shortcut’ for one of my apps (edit: in the app drawer) and now - the shortcut is gone. I can’t swipe it back to ‘show shortcut’, as the app icon is gone. I can now acces it by going to my apps and clicking on it there, but there is no way to get the shortcut back. So now I always have to go to ‘Settings’, ‘Apps and Notifications’, choose the app and click ‘Open’. Which is a big detour So I’d like to get my shortcut back. I’ve tried uninstalling the app and then re-installing it. Didn’t work. There must be a simple fix, but I just don’t know it!
Help?
Edit - So this means that the app has also disappeared from the app drawer
Do you use the standard launcher? Which software version is installed?
I can’t find the possibility to ‘swipe on ‘hide shortcut’’ on the Android phones I have access to.
!! Incanus, thank you. I didn’t think to look there. Yes I’m using Lawnchair (mainly to get rid of that search bar). So I looked into Lawnchair and found where to change the hidden apps back. Thank you!
