How to turn off autocorrect in text messaging?
Sorry if this is a silly question - but I can’t seem to find any way to turn off autocorrect/word prediction in the default text messaging app on my new Fairphone 2. It isn’t in either “Help” or “Settings”. Are there some global settings for the on-screen keyboard that I’m not finding or something?
Slightly related, it’s a bit annoying that both the default text message app and the Facebook Messenger app are called “Messenger”. Is there a way to change the app names on the screen so that the former is called “Text” or “SMS” or something?
I think, autocorrection of words is set straight in the keyboard app.
Go to “Settings”
  • Language & Input
    • Spell Checker (on/off)
I guess, that’s the neccessary setting.
I turned it “off” as well.
Edit:
@AnotherElk @Amber was correct; it’s to be set under keyboard-settings.
  • Language & Input
    • Keyboard & input methods - Android Keyboard (AOSP)
      • Text correction
That’s where you get quite a few options and can turn of “Auto-correction” etc.
Thanks all, I have sorted it now :slight_smile:
