I’ve used a Model M wireless USB keyboard and enabled Num Lock a while back to type a document. The issue is after doing that. I paired a Anker Bluetooth QWERTY keyboard that hasn’t got the number pad. Every time I restart the phone it re enabled the Num Lock from when I connected the USB keyboard.
However the workaround I’ve found is replugging the USB keyboard back in and toggling the Num Lock on and off to disable it. But after restarting the phone it’s comes back on. Is there anything I can do to reset keyboard settings in settings. I’m kinda getting tired of doing this over a month now.
P.S. I used an type A to type C USB adapter. I could use the help thanks.
