does anyone know how to make a screenshot with the FP2? i tried pressing the volume and photo-button simultaneously, but then it only makes a regular photo.
Hi, hold the volume down and the power button -> done
Tested a few seconds ago…
@kephson been there, done that, no photo …!!
Strange, it works on my FP2. Did you really hold (not just press) the power button (not the camera button) ?
yep: nothing
I filed your post from “Android 5.1” into “FP2 Help” because it is about a specific problem.
Hold both buttons together, this should work for you, too… I hope
Just tested it. It is somewhat difficult. Press both buttons and hold them for a short time
i did, several times. i only get the volume-notice.
It’s the same like with the Nexus phone, see here:
https://support.google.com/nexus/answer/2811098?hl=en
and then, just like that, it worked. thanks guys for all your responses!
stranger things have happend…
no problem
