Hello, everything is in the title.
I’ve activated the option “album cover on locked screen” in VLC options but I never see none.
Any idea ?
Thanks.
Any idea ?
Thanks.
Is that even supported on newer Android versions?
Hasn’t work for me for some years now.
Just tested it on my Nexus 4 running Android 11 and that doesn’t show any lockscreen album art either
You might want to open an issue on the VLC bugtracker.
Ok.
Thank you for your answer.
