Did you try to wait after the reboot ?
Like keeping it shut down?
After fastboot reboot
it directly goes into the rebooting cycle, which I ended after 3 mins or soâŚ
EDIT: so I flashed the device again ( ) and waited after reboot. Thatâs what happens:
- Software canât be checked for corruption⌠boot in 5s â> I press power or wait
- Device is corrupt, power off in 30s â> I presss the power button
- Fairphone logo appears (b/w), device reboots.
Where should I wait?
EDIT2: I canât mount system on that slot in TWRP (Failed to mount '/system_root' (invalid arguemnt)
hmmm, what does it mean?
First, start from a clean rom with this script twice.
Then, to get rid of âDevice is corruptâ, you should do adb reboot "dm-verity enforcing"
in TWRP.
Finally, try again. It will reboot, you just have to wait (it have to work )
Thanks I will try. But I think there is something wrong with the script. (edit: there was, check it out now) At least the conditions when files get checked are flipped somehow. I opened up an issue on Github â I hope my suggestion is right
EDIT: No success. Follwed your suggestion and didnât touch the reboot-process. After a while (2mins, 10 reboots ors so) it just changes to the other slot where the working stock is booting without problems.
EDIT2: gougeon-s corrected the issues with the script. thanks!
Iâm gougeon-s ;).
- Did you check that both slots had âsuccessâ ?
If not, go to the Troubleshooting tips part.
- Did you erase the userdata ?
fastboot -w
ah, I already did suspect
- and 2. definitely yes⌠I seem to be a hard case.
When installing stock ROM it reboots and the stock recovery asks to make a factory reset. Therefore I also tried to flash without TWRP installed (just booted it for installing magisk). It came to the point, that stock recovery asks to make the reset, but again no change to the reboot cycleâŚ
I also tried to flash just a single slot, both the same time, I tried to wipe userdate by TWRP after installing, tried to reinstall magisk after flashing⌠So far no bootable GSI LOS :-/
Has someone tested the /e/? https://forum.xda-developers.com/project-treble/trebleenabled-device-development/e-rom-t3960376
Hi @all, i flash the la OS 17 and then 16. now my FP Hang on bootloader. I flash the stock with the script (twice) but same Problem, it Hang in bootloader. When the script flash i got 2 âERRâ like partition size magist.
I will post the ERR later if you need, but what can i do? And where is the Problem?
THX
We need the errors to answerâŚ
Edit : Iâve seen youâve edited the wiki to add something about the 30secondes warnings. Does it mean you managed to flash the stock rom?
i tried some gsi images:
not booting (one reboot, then boot to recovery):
/e/ image (e-pie-20190827-UNOFFICIAL-treble_arm64_beN-img)
booting:
aosp 9 (AOSP 9.0 v123 system-arm64-ab-vanilla-nosu.img)
ArrowOS (system_arm64_ab.zip 2020-01-27)
lineageos 16 gsi (lineage-16.0-20191017-UNOFFICIAL-treble_arm64_bvN.img)
edit: my fault with lineageos16, had to factory reset after flashing. Now it works
that was me. I just âforgotâ to check the 30s warning to get the slots succeed again⌠Maybe others do the same stupid things as i didâŚ
Nice ! And what was the errors?
I had LOS 16 and I confirm it works
here the fastboot log.
fastboot getvar all say say the slots are
(bootloader) slot-count:2
(bootloader) current-slot:a
(bootloader) slot-retry-count:b:7
(bootloader) slot-success:b:No
(bootloader) slot-active:b:No
(bootloader) slot-unbootable:b:No
(bootloader) slot-retry-count:a:7
(bootloader) slot-success:a:No
(bootloader) slot-active:a:Yes
(bootloader) slot-unbootable:a:No
Slot_a.txt.pdf (21.8 KB) Slot_b.txt.pdf (21.9 KB)
I only missunderstood the 30 seconds warning⌠always choosed reboot in bootloader to flash again or try something different. But i only had to confirm the warning with power button. stupid shit
I now got lineageos working, had to do a factory reset after flashing⌠next iâll try booting /e/
It is a bit weird that current-slot: a
is before the flashing linesâŚ
If the errors youâre talking about are Invalid sparse file format at header magic
, it doesnât matter. It is because these images arenât sparse files but it works.
Please referre to Troubleshooting Tips > To get a slot-success=Yes Post #1
If you see the 30secs warnings, you have to confirm booting with the power button.
ok it works⌠schame on me, i forget to confirm on the 30sec warning xD
edit: It is a bit weird that current-slot: a is before the flashing linesâŚ
wrong copy paste
âa tip for the first post.â
if fastboot -w
fail try fastboot erase userdata
still have to do a factory reset vie recovery afterwards
Maybe âuninstallingâ the unnecessary priv apps instead of disabling them could be the better way. In the Thread Google apps keep reinstalling someone mentioned that it would be better to use
adb shell pm uninstall -k --user 0 com.qualcomm.qti.qms.service.telemtry
adb shell pm uninstall -k --user 0 com.qualcomm.qti.qms.service.connectionsecurity
adb shell pm uninstall -k --user 0 com.qualcomm.qti.optinoverlay
adb shell pm uninstall -k --user 0 com.orange.update
adb shell pm uninstall -k --user 0 com.orange.aura.oobe
instead of
adb shell pm disable-user --user 0 com.qualcomm.qti.qms.service.telemetry
adb shell pm disable-user --user 0 com.qualcomm.qti.qms.service.connectionsecurity
adb shell pm disable-user --user 0 com.qualcomm.qti.optinoverlay
adb shell pm disable-user --user 0 com.orange.update
adb shell pm disable-user --user 0 com.orange.aura.oobe
for preventing uncontrolled reactivating of those apps. But maybe this is a stock rom problem only.
By the way: it should be ok to remove com.qualcomm.qti.qms.service.trustzoneaccess as well:
adb shell pm disable-user --user 0 com.qualcomm.qti.qms.service.trustzoneaccess
You should not disable com.qualcomm.timeservice.
works, good guide, thanks for the work @all here.
feel mutch better not longer to be under the surveillance of google & partner, and to be root again
