How to copy sound recordings from the phone
Hi, I make sound recordings on the phone but cant find them when I connect the phone to the windows computer. Where should be they be stored?
Look for a folder named ‘Recording’ (if you use the default sound recorder, that is. Another app may create/use another folder).
explorer cant find anything under that name on the Fairphone
Works for me (Win 7). Have you chosen the MTP option when connecting your phone via USB?
I have the same issue. I have a mac & when i connect the phone with a USB cable i cannot find the files. It’s quite urgent actually thank you
Do you have Android File Transfer installed as explained in this support article?
