It’s funny- I would imagine FP is particularly popular with educators and speakers who might give demonstrations in venues with poor facilities. But Fairphones have no way to send presentations and videos to old-fashioned displays via a cable. Previously I did it very simply with a 3rd generation ipod touch.
But it can be done wirelessly! I spent under £25 instead of £250 buying a new projector. I’ve looked around for a simple explanation and couldn’t find one- so here it is.
You will need an existing WiFi connection and a couple of small things:
A screencast dongle. These can be called “Miracast” or "EZcast"
dongles. I used the cheapest model by Measy. They plug straight into
the back of TVs or projectors with an HDMI connector. -
If your projector is so old it has only a vga connector then you will
also need a “hdmi female to vga female adapter” I did not invent that
terminology: that is what you have to search for to find the correct
item. (I call mine a dingle).These are cheap little things but harder
to source than the “male to female” type. I found one on ebay. They often come with an
extra wire to plug the audio into the speaker or sound system of your
choice.
Attach the “hdmi female to vga female adapter” (dingle) to the Miracast dongle and then into the TV/projector. Plug the dongle into a power socket. Happily you can use the same cable as the one for your FP for this
Download the EZcast app to your fairphone. It’s free.
Switch on your projector/TV. Launch the EZCAST app on your fairphone. It will instruct you on how to setup the dongle. It will require your WiFi password to create a mini-network between the FP and your display. It will install its software on the dongle. The process takes less than 5 minutes and only needs to be done once.
All done! Now you can stream the web, show photos or documents on the big screen.
You can also use this method to cast media from your Windows PC or Mac OS 10.7+ to a display screen- but that is for another forum… There is no open source alternative yet but there will soon be one called Miraclecast.
There is a rumour this can also be acheived via the cross-platform open source media software called VLC. I have not suceeded with this, nor have I found any proper instructions for it.
I hope this helps other people looking for the same thing.
. But if you have a good WiFi connection, you can use a cheap wireless dongle to stream it instead. That’s what the above instructions are for.
