how can I check that my battery is gone or how do you check the health of your battery?
I purchased a used FP2 with an FP2-BAT01 and from my point of view the time of use is much too short.
You can install AccuBattery, from the play store, which will give you a precise value of the estimated capacity of your battery after a few days of use, or BatteryBotPro from f-droid, which will give you statuses like “Good health”, “Medium Health”.
Is the text on the battery a vertical “Fairphone” or a horizontal “Change is in your hands”?
