Great experience! Both with FP and e/OS. Everything works really well, it’s efficient and non-intrusive and so many small frustrations just vanished. I choose to keep mine with all AI features turned off, but they are available.
It feels simple, very simple, which is one of the nicest things because it is so damn easy to use and so quick to do stuff. No need to know anything special.
The only difference/quirk is the App Lounge replaces the Play Store (it is not possible to install the Play Store, it uses “MicroG” to run the same services and it clashes with Play Store). Every one of my 300+ apps has worked without problems (I don’t use a banking app).
If you look it’s full of features that just work beautifully and don’t conflict with other things, and that’s increasingly hard to get right as more complex features become standard.
I moved all my internet bookmarks across just by signing up to a Mozilla account on my old device and using that to sign in to the FP5, I hit synch and poof! All there. This was for Firefox but other browsers do similar. The default e/OS browser seemed fine but you can install any (except Safari, obviously).
De-google
Especially glad to have ditched Google given the boycott caused by their military contract’s enabling IDL attacks in Gaza. They have also been removing their past climate pledges and plugging AI everywhere instead. The privacy side was also really intrusive, especially the gmail content scanning and ads based on your actual emails. Although you can install the Gmail app you can use the built-in settings to check it without the ads and tracking, or any free email app. Murena let anyone have their own free email - no need to use their e/OS or a Fairphone so that made it especially easy to switch, although I prefer Tutanota’s free email and app.
Friendliness and familiarity
e/OS looks and feels the same as the last Android versions I used despite differences underneath, there’s a lot less bloat and far more flexibility over core apps, privacy, customizations, etc. And a lot more free storage for your stuff. You can buy e/OS pre-installed from Murena or Fairphone - price difference from Fairphone with standard Android yo-yos throughout the year.
It’s fast, reliable, looks great, hardly ever crashes. I even setup the home screen to look exactly like my old iPhone so there wasn’t a learning curve.
Updates
The software updates look and work exactly like standard Android, appear in the same place and notify you.
I’ve done 2 major Android update releases on the air - through the usual System / About / Update after being notified. No issues. Apparently e/OS is now based on lineage but no visible difference. I did expect some hassles from a non-standard setup but there haven’t been any.
FP5 handset
I got my FP5 from eBay, bought as nearly new (as I do with all tech, being a tree hugger), with standard Android 13 installed, which I wiped to install e/OS in order to de-google and dump the big tech. I had previously been affected by Apple’s deliberate slowing down of ios via the back door, and before that Samsung bloatware, it felt like very few options existed that didn’t force you to use manufacture’s own apps.
It costs less than half the cost of iPhones it buying new, and hundreds less if buying used (e/OS ones can be expensive used, you could probably make a tidy profit installing it and reselling them…)
I needed to take out the battery briefly - can’t remember exactly why - didn’t need a screwdriver but it is also definitely not going to fall out or move by itself. Unlike my old iPhone the battery is replaceable and inexpensive.
Murena
Murena gives you free email (murena.io, no need to run e/OS, Thunderbird. K9-mail or built-in phone email settings work with it) the email is running on rebewable energy, permanently free and ad-free, and free Workspace account linked to it including ability to transfer contacts, calendar events, files etc, all very smoothly. Workspace storage is small.
Workspace transfers your contacts, calendars, photos (I had to zip my photos since I went over the limit).
FP5 hardware
Moved to FP5 from iPhone X after ios16 … keep dropping my phone and managed to stand on the screen and it’s still fine. I tend to drop it from around waist height onto hard outdoor surfaces a lot but it’s nice and sturdy.
I think there might be an issue with Bluetooth headphones - can’t remember the details and it could have been resolved- I did buy a USB-C adapter/splitter with a 3.5mm port to be able to plug in my old wired headphones, which worked fine. I think it was an FP5 only issue.
WiFi is great, and texts/photo messages, I don’t do calls.
FP5 is heavier, I only notice when I’m really tired. It’s s thicker phone which I only noticed for the first few days. But I’m going to put it in a case regardless.
Accessories
I got the biowaves case (so not especially tough) but eco friendly. FP6 do an eco-friendly case with lanyard which would avoid me dropping it so much (dodgy hand grip). I have self-installed the official /e/OS build rather than paying the extra to pre-install. Everything went well bar a minor issue I had responded quickly thanks to previous info here (community is very helpful). I hardly ever smash screen protectors with I drop it compared to my previous phone with “military” case.
Accessibility - I use assistive tech at times - a specialist bluetooth vertical joystick that’s normally used on desktops or tablets - no setup was needed, and the dwell-click and scanning (switch access) work with it. I have not tried voice input to keyboard yet. It was hard to get into in advance and many accessibility products advertise iPhone/iPad compatibility or tablet only, so happy to have the FP working immediately.
Ads - the Advanced Privacy per-app per-tracker feature is excellent for blocking specific leaks by some of the dodgier ad-supported games, and the ubiquitous google firebase tracker. Far better than browser based ad blocks or primacy features.
Problems - App Lounge was flaky so I swapped to Aurora Store, It has everything on Play Store with no need to sign in. The few apps I have that require a Google/Gmail account work fine. No issue with banking or obscure apps (I have over 300 aid apps installed, none are Google ones).
Default Bliss launcher came with Bliss Weather which didn’t seem to be possible to remove (you can probably use ADB bridge but I just swapped the launcher instead, very very easy).
Phone-based unexpected sign-in confirmations eg for Google account confirming sign-in don’t appear - I think it’s only when you have it set to spoof device type and it mistakenly thinks you have a pixel - Google being Google doesn’t ask your consent for this - I think there was an additional account verification method I needed to sign up for to provide an alternative, since I won’t give Google my mobile number. The notification showed on my old iPhone which I still had.
Security updates always come late, which is my main criticism, however most of the big vulnerabilities aren’t hitting us, probably because they tend to target standard Android vulnerabilities, and big tech apps like Chrome, Yahoo mail, or bloatware, none of which are installed by default, but all of which work find regardless.
The major issue I have had moving over is actually Apple’s default/decision, which was their inability to export saved passwords until ios 17. I did have a phone 6 or 7 years old at the time.
Btw Pixel addicts often sign up to this forum just to bomb threads about FP vs Pixel, despite most of them never having tried a FP, so of you look at general FP vs alternatives posts you’ll see them brigading en masse.
