How do I change the ringtone?
Answer by Clemens
- Press the settings button (when you’re at the home screen), then System settings.
- Under “Device” you’ll find “Audio profiles”.
- Next to “General”, you have a button for settings.
- There, you can set a voice call ringtone and a video call ringtone for all incoming calls. You can choose one from all the tunes that are in your “Ringtones” folder
Additionally, you can add a specific ringtone for a person when you select them in “People” and then choose “Set ringtone” after pressing the settings button.
This question was originally placed on the old forum change ringtone.
