Although I have in mind that the user comes with root authorizations I do not find any possibility to uninstall iFixit which comes with the OS. How does it work?
you need a special App to uninstall System Apps. I use the Pro Version of this one witch works fine for me. I like the possibility to reinstall an App after uninstalled it accidentally.
regards,
Shiny
And if you donât care about fiddling around with extra file/app managers you can just choose âDisableâ and it wonât bother you. It only occupies 3MB of storage anyway.
Theres an opensource app named 'system/app moverâ
it needs busybox installed.
it does its job perfectly fine and nothing else
I need to remove it to install an updated version from f-droid.
