I am constantly encountering issues with my FP3 hotspot. 4G on the phone and perfect reception, but I have constantly occurring dips in my hotspot connections. As there is many instances where I am dependent on my phone´s internet for work, this is beyond frustrating.
Hi Alex, yes, I did a search but could not find anything. My experience can briefly be described as follows:
I set up a hotspot on my FP3 and connect with it through my Dell Windows 10 laptop
Initially the internet speed is as expected and I can use my Zoom app as normal.
Suddenly (can’t find any correlation with particular events), the internet speed drops to almost zero, and sometimes even totally disappears. When doing a speedtest on my phone when that happens, I always find it to be at least 10Mbits/s download, which should be sufficient for Zoom.
Did you check if data saver was not on? Do you have a data limit set so that it might stop the data connection at some point?
Otherwise you could try readding the APNs (Settings→Network and Internet→Mobile data→(Advanced)→APNs).
Thanks for your swift reply. Data saver was off. Not sure what you mean with readding the APN’s. Do I need to first delete them and than add them again?
