🇬🇧 🇫🇷 🇩🇪 Hoping for an upgrade to Android 8 or 9 from OpenOS, or switching to Lineage without waiting any longer?
Hello, (:fr: version originale en français plus bas) (:de: Deutsche Übersetzung unten)
:uk: Since the FP3 was released with Android 9, and the FP2 is no longer sold, I have the feeling that we’ll never see a more advanced version for an FP2 than the current version of FP open os (based on Android 7).
Now, if I bought an FP2 two years ago, it’s not to buy an FP3 now, especially, if I understood correctly, that there is no open version for the FP3.
So, isn’t it time to consider a migration to Lineage, which is preparing a version of Android 10 (and there’s even an unofficial version on this forum that is already available to the competent people)?
My primary reason is that I really like the OSMand+ application, and that it’s currently working like crazy, sometimes to the point of crashing, whereas on an iphone with the latest system, it’s very fluid. Now, this application shows a noticeable acceleration from Android 8.
And my second reason is that you don’t have to stay too far behind in updates, and if there’s no FP open evolution, you might as well take advantage of the latest Android versions without waiting any longer (I find the ability to use the phone as a desktop computer appealing, since I’m hoping it’ll allow you to use some applications on a larger screen, and with the comfort of a keyboard).
Translated with DeepL Translate: The world's most accurate translator (free version)
:fr: hello,
titre : espérer une mise-à-jour vers Android 8 ou 9 de OpenOS, ou passer sans attendre plus à Lineage ?
Puisque le FP3 est sorti avec Android 9, et que le FP2 n’est plus vendu, j’ai bien l’impression qu’on ne verra jamais de version plus avancée pour un FP2 que la version actuelle de FP open os (basée sur Android 7.
Or, si j’ai acheté un FP 2 il y a 2 ans, ce n’est pas pour acheter un FP3 maintenant, d’autant plus, si j’ai bien compris, qu’il n’y a pas de version open pour le FP3.
Du coup, le moment ne serait-il pas venu d’envisager une migration vers Lineage, qui, lui, prépare une version d’Android 10 ? (et il y a même sur ce forum une version officieuse qui est déjà proposée aux compétents)
Ma raison première est que j’aime beaucoup l’application OSMand+, et qu’actuellement, ça rame comme c’est pas possible, au point parfois de planter, alors que sur un iphone muni du dernier système, c’est très fluide. Or, cette application indique une accélération notable à partir d’Android 8.
Et ma seconde raison, c’est qu’on est quand même un peu obligé de ne pas trop rester en arrière dans les mises-à-jour, et s’il n’y a pas d’évolution de FP open, autant profiter sans attendre plus des progrès des versions plus récentes d’Android (La possibilité d’utiliser le téléphone comme ordinateur de bureau me semple séduisante, dans la mesure où j’en espère une possibilité d’exploiter certaines applications sur un écran plus grand, et avec le confort d’un clavier).
:de: Hallo,
title: in der Hoffnung auf ein Upgrade auf Android 8 oder 9 von OpenOS, oder den Wechsel zu Lineage, ohne länger zu warten?
Da das FP3 mit Android 9 veröffentlicht wurde, und das FP2 nicht mehr verkauft wird, habe ich das Gefühl, dass wir nie eine fortgeschrittenere Version für ein FP2 sehen werden, als die aktuelle Version des FP open os (basierend auf Android 7).
Nun, wenn ich vor zwei Jahren ein FP2 gekauft habe, dann nicht, um jetzt ein FP3 zu kaufen, besonders, wenn ich richtig verstanden habe, dass es keine offene Version für das FP3 gibt.
Ist es also nicht an der Zeit, eine Migration zu Lineage in Betracht zu ziehen, die eine Version von Android 10 vorbereitet (und es gibt sogar eine inoffizielle Version in diesem Forum, die den zuständigen Leuten bereits zur Verfügung steht).
Mein Hauptgrund ist, dass ich die OSMand±Anwendung wirklich mag und dass sie derzeit wie verrückt funktioniert, manchmal bis zum Absturz, während sie auf einem iPhone mit dem neuesten System sehr flüssig ist. Nun zeigt diese Anwendung eine spürbare Beschleunigung von Android 8.
Und mein zweiter Grund ist, dass man bei Updates nicht allzu weit zurückbleiben muss, und wenn es keine offene FP-Evolution gibt, kann man genauso gut die neuesten Android-Versionen nutzen, ohne länger zu warten (ich finde die Möglichkeit, das Telefon als Desktop-Computer zu benutzen, ansprechend, da ich hoffe, dass es einem erlaubt, einige Anwendungen auf einem größeren Bildschirm und mit dem Komfort einer Tastatur zu benutzen).
Übersetzt mit www.DeepL.com/Translator (kostenlose Version)
I have LineageOS with OsmAnd+ on the Fairphone 2, and it works like a charm.
So, if you’re not content with Android 7, then at least there’s no harm in checking out LineageOS.
… yet. It may still come. Or the community might manage to port LineageOS.
My advice is to test Lineage OS by yourself (also for me works like a charm with OsmAnd~), but first make a TWRP backup of your existing OpenOS before, so you can go backwards if needed. :smile:
:fr: Mon conseil est de tester LineageOS par toi même (pour moi il fonctionne parfaitement avec OsmAnd~), mais de faire un backup TWRP de ton OpenOS juste avant, ainsi tu gardes la possibilité de revenir en arrière si besoin. :smile:
:uk: Hello,
That makes me two testimonials (100% of the answers, thank you very much :slight_smile: ) that advise me to try Lineage. Why not do it?
But I have some technical questions, so I’m going to open a new post about it.
:fr: Hello,
cela me fait deux témoignages (soit 100 % des réponses, merci beaucoup :slight_smile: ) qui me conseillent d’essayer Lineage. Pourquoi ne pas le faire ?
Mais j’ai quelques questions techniques, alors je vais ouvrir un nouveau post à ce sujet.
:de: Hallo,
Das macht mich zu zwei Referenzen (100% der Antworten, vielen Dank :slight_smile: ), die mir raten, Lineage auszuprobieren. Warum nicht?
Aber ich habe ein paar technische Fragen, also werde ich einen neuen Beitrag darüber eröffnen.
