Hi everyone,
I just unpacked my FP2 yesterday and I’m very happy!
Just a quick question:
Is there a way to change the behavior of the home button? There was a post in the forum about how to change the search engine used when long pressing the home button. But what if I wanted it to open - let’s say the settings panel, or whatever - instead. Is that possible?
Thanks in advance,
kind regards
Anika
AFAIK that is not possible on standard FP OS.
On #software:fp-open you have root access and with that + #dic:xposed + #dic:gravitybox you can change that behavior.
On #software:alt-lineageos you can even simply change it in the system settings.
Perfect! Thanks for the info!
Cheers
