I recently updated some #wiki’s and #staff curated articles that contained some outdated info, but there are many more to go.
The following is a list of posts that should be updated.
If you feel up to the task please:
- write your name to the post in the list below so we know which posts are already being worked on (if two people work on the same post at the same time things tend to go wrong).
- try to make sure to update all the info in the post. That way it’s easy to see which posts are more up to date than others simply by looking at the order in the list (#wiki or #staff) (at least this is true for one-post topics).
- check all links to see if they are broken. If a link automatically gets redirected (e.g. because it lead to the old location of a support article) it would be nice if you’d change it to the new url so the site will load faster when you click the link.
If you’re really up for a challenge also change the code of the wiki from the old system ([link name][1]and then on the bottom of the page:[1]: url) to the new system ([link name](url)). - if you upgrade a post from #software:fp2-android-5-1 to #software:android-6 it will automatically reopen. If it is a one-post-topic it has to be closed again and the 2 open/close posts removed - moderators (& I believe leaders) can do that (for you).
Staff curated posts:
- #gpsguide
- make clear what tips are relevant for which FP model
@paulakreuzer
done - #updateguide Anleitung: Update für das FP2 mit root und/oder TWRP
- upgrade to #software:android-6
- #updateguide How to update your FP1(U)
- include guide to update to #macadamia.
- maybe: include info for upgrading to #dic:unifiedpartition?
- #disassemble
- move first post to own topic (+close+hide ‘closed’-post+make wiki)
- edit to make it more into a guide
- move #disassemble tag to new post (only mods can do that)
@paulakreuzer done
(Other) Wikis:
- Adjustments to forum software
- Decide if we should keep/revive this or maybe introduce a bug-tracker for the forum instead?
- @moderators
- How to create a poll
- decide if we should hide topic or update with the super-easy way to create polls now (
symbol when you create a post - pretty self explanatory) - probably @moderators, if anybody wants to weigh in please post below
- Workshops for the #efct16::tag
- is no longer a wiki, which is good, but removing the #wiki tag would bump the topic all the way to the top…
@paulakreuzer
I found a way - The following topics need to be updated to Android 6:
- ADB on the Fairphone
- Gravity Box Tweaks
- Recover/Backup user data
- Flashing XPosed
- only move the first post to #software:android-6
- Anleitung zum rooten unter Windows
- Root with superuser
- only move first post to #software:android-6
- The dictionary entries (#dic). Most of them where created before the FP2 came out and some are not updated properly. Write down which one you’ll update + your username below.
- some of the other ancient #wiki’s should maybe be unwikified, updated or just left there. please discuss by posting below.
