Hello. My FP3 headphone socket has stopped working. First occurred during a phone call, intermittently, then became continuous whenever I tried using them. It produces a static noise. I’ve tried it with a couple of sets of headphones; same thing. The speaker is fine without headphones. Has anyone else experienced this? Is there anything I can do?
The headphone jack or headphone socket is part of the top module.
You can try and see if replacing the top module helps.
You could probably also get the module from one of the following posts:
It doesn’t hurt to cautiously clean the inside of the audio jack from dust, hairs etc.
If cleaning the inside as suggested by usr_lesse leads to no results, I have a 2nd hand top module.
best regards,
