[Guide] Fairphone 4 stuck in Fastboot after /e/OS install — Full Fix
:mobile_phone: [Guide] Fairphone 4 stuck in Fastboot after /e/OS install — Full Fix
Hi everyone,
I want to share how I solved my Fairphone 4 being stuck in Fastboot Mode after trying to install /e/OS.
At first, I used the /e/OS Installer as recommended. The flashing process seemed to complete successfully, and the phone rebooted — but instead of starting /e/OS, it booted straight back into Fastboot Mode.
After some frustration, I realized I needed to fix it manually. Here’s the full step-by-step that worked for me.
:hammer_and_wrench: Problem:
  • After flashing, the phone only booted into Fastboot.
  • “Bootloader unlocked” warning showed briefly, then back to Fastboot screen.
  • No /e/OS welcome setup screen.
📋 Table of Contents (click to expand)
Full Steps to Fix It
Step 1: Download the correct /e/OS version
:backhand_index_pointing_right: Download /e/OS for Fairphone 4
Step 2: Extract the /e/OS archive
  • Extract .zip fully using Windows unzipper, 7-Zip, or WinRAR.
  • Look for .img files like boot.img, dtbo.img, vbmeta.img, super.img, etc.
Step 3: Install platform-tools (adb/fastboot)
:backhand_index_pointing_right: Download Platform Tools
Step 4: Connect phone and verify Fastboot
Step 5: Flash firmware images
fastboot flash boot boot.img
fastboot flash dtbo dtbo.img
fastboot flash vbmeta vbmeta.img --disable-verity --disable-verification
fastboot flash super super.img
fastboot flash product product.img
fastboot flash vendor vendor.img
fastboot flash odm odm.img
fastboot flash recovery recovery.img
Step 6: Erase userdata
fastboot erase userdata
Step 7: Check active slot
fastboot getvar current-slot
Step 8: Switch slot (if needed)
fastboot set_active a
Step 9: Reboot
fastboot reboot
First boot can take 5–7 minutes — be patient.
:tada: Result
:white_check_mark: Booted into /e/OS Welcome screen!
:warning: Important Final Tips
:package: Useful References
To avoid confusion … There was a standalone Easy Installer, but it was abandoned in favour of the current /e/OS installer using a compatible browser. Which one was it?
ahh yes, sorry. I used the current one.
I removed the word “easy” in your initial post.
