grouping app icons in folders is possible but hard to do. Can somebody help?
I try to place one icon on another to group them. But the other icon jumps away. I move back and forth again and again, und suddenly, the white ring appears so I can group the icons.
But it works just by chance!
See these screenshots:
Icon jumps away…
It really is difficult and @Chris_R is right, you’ll get better at it by trying. But if you absolutely can’t get the hang of it you could alternatively use apps like Apps2Org . It lets you categorize your Apps and you can put shortcuts to a Category on your homescreen instead of folders. A little bonus is, if you categorize all your apps you can have a “folder” that is automatically filled with newly downloaded (not yet categorized) apps.
