Green bar in top right corner of screen
Hello
Not sure if this is Fairphone-specific but on my wife’s FP4 this small green bar has started appearing in the top right hand corner of the screen next to the battery icon. It’s like the microphone or camera icon when those are in use, only it doesn’t have any icon in it.
I’ve not been able to correlate it with any app having been installed or being in use. Restarting the phone makes it go away.
Does anyone happen to know what this is?
As described here?
Did you figure this out? I’ve also just started getting it. It’s similar but not the same as the camera dot.
