I have a FP4 with E/OS.
Used to be, everything worked, and was just a bit different from my old kraken-samsung.
Then, I think it was, when an update hit, my camera lost some functions. Around Summer time. Tried waiting for a patch, have started googling for help since.
Used to be: The standard Camera App would have a button to switch between wide angle and normal. This button was lost.
The Camera App crashes every time I swith to front Camera.
I cannot Access Camera from Signal or Whatsapp. - meaning I cannot run a Signal-Desktop-App
I’ve tried a factory reset, it might have made it even worse.
Anyhow:
Front Camera works in Open-Camera. So I assume THIS is not a hardware problem. (Open-Camera is really really slow to take a picture though, basically unusable for snapshots)
since the factory reset, the FP4 Camera doesn’t start, FOSS-Camera neither. Some QR-Scanners seem to be able to access Camera.
How can i do a (self)check if it’s hardware or software?
How can i change which camera app is the “main” ?
can i make signal access opencamera instead of eos-app ?
any other hints?
Android 13
/e/ OS 2.4.1-t-20241009439851-officialFP4
