GCam Wichaya Astrophotography didn't work
I was going to take some night pictures with my FP4 and Gcams Wichaya v1.5.
So I used the Astrophotography mode in the night mode. Then always a countdown at 4:09 starts and stops at 3:46 doesn’t matter if the photo is bright enough or not.
How it is on your phones?
Bug or feature?
Does anyone have experience with night photos? (with smartphones)
Setting AWB on, no RAW, Astro on, Focus auto, 4:3. Dark but lighted street.
Setting AWB off, no RAW, Astro on, Timer 3s, Focus wide, 4:3. Dark room with window:
First one is great, but the second one isn’t so impressive.
I see the “NIGHT” label in the picture filename. That means it’s just using night mode. Below are pics taken with my Pixel 3 in astrophotography mode. From what I’ve seen and experienced is that Gcam mods on non-Pixel phones give okay pics, but it doesn’t come close to a real Pixel. Do you by the way hold the phone? Or do you place it on a stand? For astrophotography mode it has to stand perfectly still. For these pics I just flipped the phone and left it laying on the ground for 5 minutes. It was in my garden, so in a remote area outside the city the result would be better.
Ahh, now I saw, that the button has to change to a star…
I used a stand and timer to hold it extra still.
But what make it swap to astro?
Also, it is still strange, that it stops the countdown after 25 s.
And of course, I had bad conditions, but it should be enough to test how the mode works. :man_shrugging:
Okay I found the problem.
The Wichaya Version just won’t do it, so I tried Arnova and BSG.
They are both smoother at all, Arnova is switching to astrophotography after some seconds laying still and BSG is switching instantly on laying down + has an “on” option instead of only automatic/off.
I will try BSG this day/night, and maybe I’m not in the city this weekend to test it on a nice sky.
(The BSG Version also has a lot more setting options than Wichaya or Arnova.)
So if it technically works this night, my problem should be solved. :slight_smile:
I will edit the title, if someone is searching for information about GCam and Wichaya.
Edit: I’ll use “Greatness” as gcam version, because pictures with Arnova and BSG looking very different to Wichaya or “Greatness”. More realistic colors, but less sharp. (maybe an HDR thing).
Questionable which is better, but Greatness is nearly Wichaya, but with working astrophotography.
(Nikita crashed sometimes)
Best shot. :man_shrugging:
Greatness always shows 15 s and I have to turn astrophotography out and on to activate it.
BSG shows a bigger counter, but stops after about 10 s. Same Arnova.
“NIGHT” is always in the name, maybe because astro is inside night mode? Definitely shown as astro on.
And nothing changes if I cover up the lens and start.
Chances are pretty low, that it will be better on a good sky.
Maybe its not the mod, just the FP4. :frowning:
Does anyone tried that on a FP?
Hi All,
I’m on holiday on the south coast in the UK. Beautiful dark skies…where you can see the Milky Way with the naked eye.
For decades I’ve been interested in space. I used to use a Google Pixel 4XL that was able to do astrophotography, and I was amazed! However, the 4XL has…limitations.
So, hen shopping for a new phone, I picked the FP4, as it was repairable, and with a replaceable battery. Very cool!
However, the built-in camera app is only so-so. So, I found a version of the camera app off a Pixel, and started using it. Wahey! happy days…or so I thought.
It would randomly stop working (camera busy, so the app just showed a black screen), necessitating a reboot of the phone to be able to take another picture.
Now that I’m on holiday, I’d love to be able to use NightSight…but I can’t seem to find an app that will work with the FP4 to allow this.
Is the fp4 camera capable of this? Can it be upgraded to the fp5 camera? Is there an app that will let me, however clumsily, accomplish this?
If not, I’m afraid that I might head back into the clingy embrace of Google for the Pixel 8 next month!
-Ken
It’s worth mentioning that I downloaded the latest KSG and Wichaya apps from Google Camera Ports Download with no luck!
-Ken
BSG?
Will move your topic over to an older one.
No thats not possible and a software not hardware thing
Yep, that’s what I meant. Thanks.
Yep, that’s what I was afraid of. Ah well.
