The paid-for G Data “Mobile Internet Security Plus VPN” app for Android, version 25.11.8 (current), repeatedly fails to connect to the VPN infrastructure maintained by G Data Software AG (www.gdata.de), when using the Fairphone 2 mobile, running Android 5.1, using the Fairphone OS 1.11.1 (build r4275.1).
The G Data app involved is basically a malware prevention and abuse deflection system, having a VPN-service as an additional paid-for module. It should be said that everythings works properly so far, except the build-in VPN service.
The technical support staff of the reknown involved German security firm has been contacted for this issue, a fortnight ago. Those folks are still working on it, and some progress has meanwhile been made, but input of the Fairphone.com forum might be prove very helpful to eventually resolve it.
Explanation of the problem
The status field of the paid-for VPN subscribtion says that it has been accepted.
The module tries to connect one of the VPN servers, in this case Amsterdam:
- Eventually, after an time-out occurs an Error message is show, saying there “No available internet connection” (which is dead wrong, anyway).
Analysis of various attempts
The lock of the Fairphone 2 has been pre-set, using a PIN or pattern, therefore the VPN ability of the Fairphone itself should have been set as being “unlocked”.
It does not matter, it seems, if the ‘Data compression’ switch of the VPN Module of the G Data app has been turned either “off” or “on”. Default seems to be “on”.
The possibility of interfering firewall settings of the common wifi-router involved, has also been excluded, by (temporally) disabling the wall while testing the VPN.
Certainly, I did not install myself a Android firewall app onto the Fairphone 2. At least, not yet. Are there a specific Fairphone firewall settings available, anyway?
Trying to connect to any other of the available nearby VPN servers of the G Data AG, e.g. Belgium and Sweden, does not resolve the issue either.
It could be that some, yet unknown, internal Fairphone OS setting in the current Android 5.1 build is interfering with the TCP/IP-setup of the needed VPN tunnel?
Let me know. Any technical help or guidance to resolve this nagging issue by help given by Fairphone.com and/or its Forum users will be much appreciated.
