Someone assembled a 3D printed tablet from a Framework, thanks to the CAD files being openly available. Here’s the guide for it:
It’s worth noting that
- V2 has only been in production since July
- I have the V1 and it’s working fine too
- I would call it Fair in the sense of the Fairphone There is no effort to source fairly mined material nor pay extra wages to the factory workers.
The only indication that there is any general care is the Carbon offsetting, which I consider a devious attempt to greenwash continued consumer consumption.
The cardboard packaging and repairability Fairphone and Framework do have in common as well a number of consumers.
All the best with the phone by the way ![]()
OK Here’s some shocking news, amazing upgrades AMD or 16" screen . . . . enough to make me cry. Their market crashed under new views ![]()
Ok The announcements came a bit late so scroll the video to 26 min and 26 seconds to start the movie, it really is a must and shoving what has been accomplished since the last upgrade in June 2022
Framework published a cheap DIY fix for the Gen11 rtc battery drain issue. Voids warranty, though, but that’s inevitable for DIY repairs.
Voiding the warranty isn’t inevitable for DIY repairs. Framework legitimately seems to support self-repair and third-party repair, and I think nrp tries to make the warranty situation clear in what he says (note nrp, the person posting this, is Framework’s founder):
In other words, if you damage the mainboard by your rework, they’re not going to cover that under the warranty, but that doesn’t mean the warranty is void. If you implement the fix, and, for example, your keyboard stops working some time later, or you have problems with one of the known defects (fraying USB cable, loosening hinge, etc), the warranty will still cover those.
This is as warranties should be: simply repairing or modifying the device shouldn’t void the warranty, it should just mean that self-inflicted damage isn’t covered. That is, of course, somewhat up to the interpretation of the company, but that’s also what companies can build reputations on.
A very helpful clarification. Thanks!
I’d really like to know why they dont put 2 USB-C slots in one module here:
Producing this would probably cost less than 1 € more.
Such a waste of slots and space…
This is discussed at framework forum also.
Dual USB-C Expansion Card Mockup - Creators & Developers / Expansion Card - Framework Community
In the second post an employee explains why it is hard to achieve.
It is much more complicated than that. Right now this module is just an extension without much electronic stuff around it.
Building a USB hub, however, is something else entirely.
Here is a whole discussion about your exact question:
EDIT: too late ![]()
Ok. Then it might cost 20 € instead of 10 €.
But if we accept some small limitations (for example only one of the USB-C ports can do power supply), then i can be possible.
If it was that easy it would have been done two years ago. And if you read the relevant topics you will see Framework have thought about and are still thinking about it.
So can you wait ?
Sure. I didn’t intend to buy one this year. ![]()
Out of curiosity 13" or 16" ![]()
No, I don’t need a new laptop at the moment.
I’m just following the development of Framework a bit.
Pair up with frame.work? Seems like an obvious collab. Same mission, somewhat same approach.
