FP6 not being detected by fastboot - can't install /e/OS
Hey Lidwien :slight_smile:
Thank you for your post!
Just to be sure that I got it right: The OS-patchlevel needs to be at least the patchlevel of the bootloeader, right?
I’m asking because I got my FP6 on monday and I flashed e/OS.
Today I updated e/OS to the newly released e/OS 3.4 and ‘fastboot flashing get_unlock_ability’ still returns ‘0’
As far as I remember, the security patchlevel of the pre-installed FP OS was something with November and after installing the e/OS update today I expected it to be definitely at least the security patchlevel of the pre-Installed Fairphone OS.
The Date in the e/OS Version is ‘20260114’. So I guess it means that the security patch level is 2026-01-14?
I hope someone can help me with this :slight_smile:
Best,
Ralf
according to https://support.fairphone.com/hc/en-us/articles/18896094650513-How-to-manually-install-Android-on-your-Fairphone#01HB8ZZ1BMMQNSNMFT3YXDBXA0
[Current] FP6.QREL.15.162.0.20251121144015_VS1V-factory.zip
Version: FP6.QREL.15.162.0
Release Date: 15 December 2025
Security Patch: 05 November 2025
:warning: Security fixes
This /e/OS 3.4 version includes all Android security patches available as of January, 1st.
what is the “allow OEM unlock” button status in Developer Options ?
I didn’t unlock the Developer Options since I flashed e OS and just did. ‘allow OEM unlock’ is disabled.
enable it,
reboot to fastboot mode,
now what is the output for
‘allow OEM unlock’ can’t be enabled because ‘bootloader is already unlocked’
this is not the expected behavior…
on my unlocked FP3 i can switch from enable to disable
(even if a pop up message say that rebooting is needed for the change to be taken in account)
in my guide i wrote:
and
to keep unlock_ability to 1
Oh dear! I remember that I read that. But after I read your guide and wanted to download e OS, I found the web-installer and used that instead of manually flashing.
I guess it’s too late now to lock the bootloader again?
i won’t encourage you to relock now.
but to take the safe way and restore FairphoneOS also Without Relocking then reinstall /e/ on a sane base before relocking.
since a few mounth i see too much bricked phone on both /e/ and Fairphone Forums !
Ok, so, reflashing the stock Fairphone OS
then
following your guide
right? :slight_smile:
this is my advise but it is your phone…
Thanks for your help!
I’ll do so and leave a note when I finished or bricked :slight_smile:
what is the bootloader status ?
fastboot oem device-info
(bootloader) Verity mode: true
(bootloader) Device unlocked: true
(bootloader) Device critical unlocked: true
(bootloader) Charger screen enabled: true
OKAY [ 0.003s]
Finished. Total time: 0.003s
good luck, good night, it is 02h43 here i am going to sleep.
Thanks!
Same timezone here :slight_smile:
Thank you! These directions sorted out my issues while I was installing e/OS and it went off without a hitch once I updated all of my drivers!
