So I got my FF6 and I ran into two “issues”:
First, is there a way to change DPI? I notice some apps are rather large compared to the FF4, for example in Instagram, the story icons are huge, I get about half the icons on the same width of display compared to what I had set my FF4 to and I am on the smallest text size already.
Also, I notice there are no activity symbols when there is data flow on either WiFi or mobile data and there are no icons for active VoLTE and VoWIFI connections. Is there a way to bring these back?
There are, these are the round icons next to the signal
Very strange as I only see the two signal and the WiFi bars and definitely no VoLTE/VoWifi icons despite them being on and active for both SIMs and I know what to look for…
…you can’t set the DPI directly but you should be able to change font size and “display size” to predefined values via the general settings menus.
I don’t have a FP6 nor Insta but that should do the trick.
And is both working or not? I never had a VoLTE sign on any phone (luckily) and I think its provider dependent
Yep, these are already all set to the minimum
I got the vowifi icon on my FF4 which I switched from. Volte was not supported on that phone with my provider…
So and you know the FP6 is supported? And the question remains: does it work?
Yes, I’ve confirmed both with the system function that lists the volte status and I’ve already placed calls where the network stayed on 4G during the call without a downgrade to 3G.
