@moki and all of you: Hello
At end of this post, calyxos-for-fairphone-5, you let know that you were able to install CalixOS on the FP5.
This post is closed and my question now is:
How and where did you obtain the install img?
Because it is still not available from the CalixOS website.
I have already installed LineageOS on it without any problems, so if I have the CalixOS install I will manage to do it.
Thanks.
FP5 āTemporarily removedā I donāt know why.
Thanks, I know that the install is removed, but @moki has managed to install so thatās why I ask.
the post is from a year ago, so my guess would be that the temporary removal hadnāt happened by that time yet.
That normally happens when the FPOS SPL is newer than the Calyx SPL, thus will be back in a few days
Out of curiosity, could you elaborate a little more on this topic? Why is a difference in the SPL versions critical. Is it the same SPL code base for both projects and does the SPL play any part in the vendor security patch level? I just donāt understand whatās the issue that could go wrong.
Please do some reading in the forum why the security patch level is critical, there are many topics discussing this. What could go wrong? A hard brick!
Never mind, I was just very confused. I thought you meant the āSecond Program Loaderā which is part of how ROMs get booted up on phones⦠and is always appreviated SPL. I never use SPL for Security Patch Level⦠but of course, makes sense.
Yeah using abbreviations always has room for misunderstandingsš
