same issue here with the FP5. Minimum call volume is way too loud
Hi nad welcome to the community,
I created a topic for you as you posted in a FP3 topic and kindly ask to not mix devices.
Hi, I’ve the same issue with my FP5 (minimum call volume is too loud). Is there a solution to this problem ?
Thanks
Hi, same problem here. I doubt reboot and battery removal will solve the issue…
