Hi community,
i checked the Forum and general Android 11 help, but no luck.
My FP4 won’t vibrate in Messages/SMS. In other Messengers, Calls, Alarms and Mail it works fine.
Vibration is activated in “Vibration & haptic strength”, Messages app and specific conversations.
Also haptic feedback works. Vibrator Self test worked fine.
I already tried: Vibration, Sound and Silent Mode (with different sounds and volumes).
NO energy saver, NO Do not disturb activated. Also put Messages as exception in Do not disturb. The same with or without usb-charger connected.
Recent Update, restarted several times.
Build number: FP4.FPWA.128.20220516
So i am really clueless. Help is appreciated. Thanks in advance!
Bonus question: I would like to have an easy switch to only SMS and Calls vibrating while everything is silent. That should work via Do not disturb (through exceptions) or Battery Saver (with muted other apps), if Messages would vibrate at all, right?
