🇩🇪 🇬🇧 FP4 Sudden Death
Hallo Leute,
mein Fairphone ist vor ein paar Wochen einfach bei 3-4 % Akku ausgegangen und seitdem nie wieder angegangen. Erst dachte ich, der Akku sei defekt, und habe einen neuen gekauft.
Leider ohne Erfolg. Seit Tag 1 schreibe ich mit dem Support → Garantie wird wohl nichts, da ich es vor 2,5 Jahren bei einem Reseller erworben habe.
Gibt es Reparaturshops, die nicht einfach nur wahllos alle Module tauschen? Denn ich ###!!%% habe kein Backup, da ich gleichzeitig mein NAS verbastelt habe…
Welche Optionen habe ich? Welche Module könnten sinnvoll sein zu tauschen?
Hi everyone,
My Fairphone suddenly turned off a few weeks ago at 3-4% battery and hasn’t turned back on since. At first, I thought the battery was dead and bought a new one. Unfortunately, that didn’t help.
I’ve been in contact with support since day one – but it seems there won’t be any warranty coverage since I bought it 2.5 years ago from a reseller.
Are there repair shops that don’t just randomly swap out all the modules? Because I ###!!%% don’t have a backup, as I was also messing around with my NAS at the same time…
What options do I have? Which modules might make sense to replace?
In a case like this I would start by removing all the modules, then clean all contacts including those of the battery compartment.
Use cotton buds and high-grade 90° surgical alcohol or isopropanol.
Leave to dry for several hours, then reassemble carefully. Make sure all connectors fit properly.
Be careful not to strip the screws. It’s worth getting a good quality Phillips #00 screwdriver if you don’t already have one. To remove the modules you shouldn’t need to remove any black screws if I remember correctly, only silver ones. The black Phillips screws round the sides are for the screen, remove that later if necessary.
You shouldn’t need to remove the three black Torx screws of the processor shield.
Ifixit tear-down guide:
