I have the same problem and your workaround saved my ass, don’t know what I would do otherwise. Thank you very much!
For me WIFI and microphone still work properly 24h later as well, with the workaround. Hoping for a quick fix still.
Hi Lars, sorry for my late reply. It was (and actually am) very busy the last weeks, which is, why I couldn’t do any further research for this issue. I switched my eSIM to my business phone and therefore I’m fine for the time being.
What I found out in the meantime is, that, when I simply boot it via fastboot with boot.img it works perfectly fine. I had it running for the last couple weeks straight, of course without root due to the regular boot.img (Jeez, do ads stink
I just made sure not to run out of battery power and I was fine. Last night though, I forgot the charge it and I had to redo the whole processes of directly booting boot.img via fastboot, because I’ve experienced the issue again elsewise ![]()
Yes, my backup was written to the internal storage. Since I had it running (and now have it again running) I tried to pull my backup just via file transfer, but after quite some time it got awfully slow and could not be completed. Don’t know what that was all about.
I will take a deeper look into SwiftBU. Thx for the hint!
Hi CransNeighbour,
thank you for your very answer!
As you can see, I already figured out, that booting directly into boot.img via fastboot works surprisingly fine ![]()
After reading your post here I tried to patch the boot.img which I used for booting into via magisk, just the way I would usually patch any boot.img. But when I tried to boot straight into the patched boot.img via fastboot I ran into the same problem as before: My phone would be stable after booting as long as it has power. But I can’t use it since it reboots like 15 seconds after entering the unlock code. BTW, I am almost certain that it’s not a problem with a SIM PIN, since I usually use an eSIM (without PIN) and right now don’t use a SIM at all.
BTW, I don’t experience any of your describes problems. After booting into regular boot.img my phone works, as described. perfectly fine. Wifi is not a problem at all. When I am not at home, I will simply open a personal hotspot on my business phone, where my eSIM is, and connect to it. Then I use it pretty much the way I would usually do. Well, besides being annoyed by the disadvantages of an unrooted phone ![]()
Have you had the chance for some more diggin into the problem by any chance? What makes you think that the issue could be resolved relatively easy? Would be great of course.
It is definitely not the SIM pin. And it’s most likely neither one.
EDIT due to some weird limitations: Has anyone by any chance tried already, if the new software update solves this issue here as well?
EDIT 2: The Update does not resolve the issue! But booting straight into boot.img as a workaround still works like charm.
Has anybody ever managed to bypass Widevine restrictions? To make it back to L1 again?
Does anyone know where I can find a boot image? I’m trying to root my phone and I’ve unlocked the boot loader, I’ve got Magisk, but even though I used it to try to install what I thought was the patched image, the phone is still unrooted.
Moved your post here
Maybe here you find what you need
else maybe hints above
Sorry for hijacking the thread.
I just updated my FP4 to LineageOS 21 and wanted to add root access via Magisk
However when I flash the boot (or just boot the patched boot image) I have no wifi anymore.
Now I read some posts that this seems common. Is this really how it’s meant to be? With LOS20 I had a patched boot image where I always had wifi and root (if needed). But now it seems I have to decide and either boot “normally” (without root) or with the patched boot image (and then without wifi).
But how am I supposed to make my backups to my server if I can’t have both?
— EDIT —
I found the solution on how I did it the last time. This post here describes it very well:
Step-by-step:
Patch the downloaded stock boot.img with Magisk
Transfer / adb pull that patched boot.img to your PC
Reboot to fastboot adb reboot bootloader and temporarily boot from the patched boot.img fastboot boot /path/to/patched_boot.img
Do not flash that boot.img!!!
Wait for the device to boot (took a bit longer than usual)
Open the Magisk app (press Cancel when asked to perform Additional Setup), choose direct install and reboot
You seem to have solved it already but in case you run into something similar in the future:
Wifi/Bluetooth/etc. problems are usually an indicator that you aren’t booting the right boot.img, did you patch the one of the LOS version you had installed? ![]()
(Not that it matters really, if you can get to Magisk from a temporarily rooted system and run the proper install you’re good to go)
Oh and welcome to the community ![]()
I want to make an update from an old Android 11 to the version actually offered by “system” → “update”. It is Android 13.
Is there something special to consider? Other than you provided in FP4 Root Access is possible, maybe a bit risky - #43 by hirnsushi?
I’d be more concerned about the regular system update in that case, who knows how much testing the upgrade path 11 → 13 got (if that’s actually what’s offered through ota, maybe it’s 11 → 12, 12 → 13 in the background, I don’t remember how we got 12, looong time ago…)
Personally I would go for a completely fresh install after such a long time, less chance of subtle issues that only manifest themselves after a bit of time.
You should really create proper backups either way, and as long as you don’t decide to lock the bootloader or start changing the partition layout I don’t see how this could go wrong in such a fashion that it’s not easily recoverable (but there’s of course always a way
Thank you, I’ll go that way if it’s time.
Should I expect problems letting side-loaded apps get access to accessibility services? I don’t like, what Google did re. restricting permissions to use my own phone as I want to.
“If you are not root, it’s not your device”.
Hi! Has anyone ever rooted a FP4 stock running Android 15?
I had to re-root my FP4 after the upgrade to A15. Don’t know if that is the same procedure from the beginning, but it works for me.
First of all thanks for your effort and post that many people use here.
I’ve used it as well and it works…and somehow not.
Could you maybe refine the post with more explicit step description for dummies?
Some things confuse me:
*first of all my magisk does not show any version under “latest”
*then when you write “Open the Magisk app (press Cancel when asked to perform Additional Setup), choose direct install and reboot” –> I do not select anything I just immediately press direct install?
* Under 3. –> I do not flash, really just fastboot right?
I think I do something wrong while believing following your guide ![]()
I assume I am not rooted when I select the modules under Magisk and cannot select any file (like LSposed) right?
I haven’t used Magisk in quite some time, maybe the newer releases moved stuff around, not sure ![]()
If you don’t get a popup that asks for additional setup, then yes, just proceed with the direct install.
Yes, you should only fastboot boot the image, but it’s not just fastboot, don’t forget the boot part (and nameofyourboot.img after that of course).
When you open the Magisk app it should show some information directly on the main screen, look for something like “Enabled: yes”, at least that used to be the case.
Another option to check for root is just launching an app that needs root, if you don’t get a prompt to grant root permissions, then yes, you’re probably not rooted.
Okay I see - thanks for the quick response!
Then maybe another question: Do I also need to install Magisk in a certain way? I have installed it through F-Droid and then went into rooting as you did. I’m confused because here you mention to install Magisk via Magisk again?
While booted from that image we have root privileges available to us and
we use those to install Magisk through the app. Magisk patches the real
boot partition directly and after a reboot we have a working Magisk
installation.
One is the Magisk app, which you can install from F-Droid, official Github releases, etc., the other is the installation procedure inside the Magisk app itself.
The Magisk app alone doesn’t provide you with root, you need to either patch a boot.img in the app and flash it, or, as we’re doing here, perform a direct install from within the app, which creates an easily restorable backup of your boot partition and then patches the partition directly.
The benefit of doing it that way is that you a) don’t have to flash it yourself (less risk) and b) since Magisk automatically creates the backup, you can uninstall → restore images in case of an OTA update, which you’d have to do manually otherwise.
