FP4 not charging after loudspeaker change
Hello !
I changed the loudspeaker part of my Fairphone 4 but after doing so, my fairphone doesn’t charge, including with the old spare part, even though it did before.
I suppose it is the result of my replacement of the part, something must have gotten damaged on the main board, even though I followed the instructions. If I had to guess, I’d say it was during the use of a credit card to dislodge the old part.
Is there any way to know more and to be sure, and then to fix the problem ?
Thank you !
