My new FP4 dual charger broke incredibly easily. The charger fell from my nightstand causing the end of the 18w charger to break off completely (see picture), has this happened with others? Seems like that if you are trying to make durable / sustainable stuff it needs to be a bit more robust than this should it not?
Everything can break, if not used in a correct way.
But what exactly broke? Looks like the cable, not the charger.
Looking at the chargers the e at the end of the charger is attached to the plug so it isnât clear from the image what is broken. Maybe the word Fairphone is the other direction on the other side??
For example incanus thought it may be the cable and the part held in your hand doesnât look like the plug, which seems a bit difficult to break off.
So is it the end of the cable? It really isnât clear
Thatâs the USB C to USB A adapter of either the USB-C to USB-C Cable 2.0 - Accessory | Fairphone or the USB-C 3.2 Long Life Cable - Fairphone 3/3+ | Fairphone that snapped off.
I would #contactsupport and ask for a replacement as that clearly shouldnât happen. I hope theyâll just let you keep the broken one as well, since that USB C plug still should be fine. No need to produce more e-waste.
Hello ! I had the excact same issue. Twice.
My first cable broke after about 5 weeks of use. I brought it back to the store (still waiting for a refund/replacement). I bought a new one less than 2 weeks ago and it just broke in the exact same way than the 1st one even though I was being extra careful.
There is definitely an issue with this cableâŚ
Hi and welcome to the forum.
Can you confirm which of the three cables you had this problem with?
Hello and thanks for the fast answer ! I just checked and itâs the 1st one of your list USB C 2.0 which can be connected to USB A or C
Have a lovely evening
So which bit broke ? One of the plugs that went into the charger, was it the adapter to USB A or the fitted USBC, or was the other end with only the USBC?
A picture speaks a thousand words ![]()
Sorry I donât have a picture !!
So, it is the whole Usb A metal part that fell out of the black ârubberâ part that was containing it. I tried to glu it back in but it didnât work.
Let me know if thatâs clear enough!
Thanks.
If you have the âfirstâ one that has the adapter then the cable is still usable for USBC to USBC.
It is hard to imagine the metal part fell out unless it was only help in by a millimeter. So Iâm trying to imagine what happened. You used the USB A adapter rather than the USB C and when you pulled it out the metal part was left in the charger.
It is surprising that the metal was not attached to the surround well enough to be pulled out a thousand times ???
Yes, exactly, so i charge my phone with this cable in a charger through USB A. I did not even pull the cable out of the charger. I was just charging the phone and I think that everytime the cable wasnât 100% straight it loosened the USB A part a bit, which ended up falling out after a few uses.
With the first charger I thought i had maybe pulled too much or sth, so I was super careful with the new one, not using the phone while charging etc, but it broke even faster. ![]()
I know i can still use USB c to USB c but itâs useless for me since i donât have any charger or other device where i can plug a USB C ![]()
Thatâs more than a little odd. Apart from Fairphone sending you a new cable, again, then maybe they can send you a bag of adapters. I know thatâs not really funny, but if the cable is OK they ideally would have an option to replace the adapter ~ given the sustainabilty blurb I read ![]()
I have had the same problem. See the attached picture.
I contacted Support and asked for a replacement but no answer yet.
Thanks for the really informative image. Hopefully you are aware that it is guaranteed for 2 years so you should be able to get a replacement.
It seems an unusual failure and I do consider it crazy a design fault even though 99% may be OK. Though without asking Fairphone there is the question of how many they sold.
It could be a 10% failure ![]()
Hope itâs not that it may be made of recycled plastic which doesnât grip the USB A part well enough.
Hope you get another quickly or get the money back and buy an alternative.
Still in theory you only need a USB C male to USB A female adapter. Looks like Fairphone could do with a stock of those, after all the rest of the cable may be OK for ages.
Further, I hope those that have experienced this werenât pulling on the cable to remove it.
A firm grip on the molded cover would help prevent this.
Update:
It is a known issue and Fairphone works on an improved one.
I got three options to solve the problem:
- Replacement of the cable, as soon as possible, but an old version.
- Replacement later (approximately in August). The improved version.
- Refund
Same problem, We bought two Fairphone 4s in April. In the last two weeks, the USB connector has detached, and no longer works.
Like others, Iâm surprised and disappointed - I was so pleased with the covered cable, thinking the charger as a whole woul dbe very durable. I havenât contact Fairphone yet but will do.
