Yep I also get the black screen - quite often on third party apps e.g. Instagram or WhatsApp. The stock camera app usually works OK or at least always will after a reboot. I can’t remember the last time the camera worked on a third party app.
As others have noted restricting access to apps other than stock camera made no difference.
Hi all, I wanted to mention that I am having the exact same issue and can confirm @mde observations. Just returned from holidays, Fairphone 4, Stock Camera app AND Wichaya GCam port; taking lots of pictures, camera reliably goes black after a few times removing phone from pocket, switching on, taking pictures.
I did not observe the flashlight issue.
What and How it happens:
starting app - no issue. Switching to video (GCam): SOMETIMES it never opens. Switching back to camera: ok. In other times, it goes black and BOTH GCam and stock app remain black.
Switching in Video mode from normal Video to Time Lapse or Slow Motion: App entirely crashes.
Both Stock app and GCam: Camera not showing anything → closing and re-opening app helps in 50% of the cases. In other cases, only restart helps.
I have tried deleting cache - and twice also storage. Helped only initially.
Switching camera apps has no effect. But Stock app is less likely to crash in video mode.
Once it even happened that both camera apps remained black even after restart.
GCam only: app freezes (not: black screen) when switching to Slow Motion.
Why I use both apps:
GCam has slightly more options and better HDR quality. But stabilization doesn’t work for me. For that, I use the stock app. Also: stock app is less likely to crash in slo-mo mode.
It is thus clear that the issue is not isolated.
I am ready to approach support. What do I need? @mde what was your workaround?
I don’t really have a workaround apart from restarting the phone when this happens, which has always fixed it reliably for me. This does not seem to be the case for you?
The only time I’m running into this is pretty much on holidays as I don’t usually take pictures that often.
Thanks for the reply.
Got the error again, easily. It is 100% repeatable, simply by using the camera often. A few photos or videos, switching off, switching on again after 1 minute and taking another picture (with any camera app) will reliably crash the camera. Only restart helps, which is VERY annoying.
I checked the torch and indeed it says “camera in use”, despite killing the app.
If you have multiple camera apps that may cause a problem if one doesn’t quite let go of the software switching.
have you tried clearing the cache and storage of each camera app more frequnelty and have you tried using the phone in Safe mode where only the default camera with be available?
Support is only likely to help resolve this if you remove GCam to start with and from then . . .
I had some issues last week on holidays as well. The use was not really even that intense. But I’m not sure if I can see a connection to light conditions. Sometimes it was also only the selfie camera that failed - even though it was the first time I tried to use it after the last reboot. Another reboot always fixed it, though.
This bug happened twice in one day in Prague two days ago. Has anyone heard anything from the support or whatever about this now over 1 year old issue?
No thats kind of a dead end, as hardly reproducible… With the beginning of summer and sun it happend multiple times to me, however not always, so how to investigate?
