… got it solved by switching to the new python build script and - probably more important - by pulling some recent fixes for the signature spoofing patches.
I’ve got a fp4 running lineageos 20 w/ microg and f-droid baked in now, yay \o/
if anyone is interested, please have a look at Index of /stuff/fp4
Thanks @mmustermann for keeping an eye open for that commit! MCC 310 is exactly T-Mobile and this commit seems to be the fix for my VoLTE problem! This really makes me happy! Finally I have a fully functional FP4 in the USA running LOS. Thank y’all for your efforts and contributions!
I’m trying to build LineageOS 20.0 for myself. For LineageOS 19.1, earlier in this thread, the following roomservice.xml was shared: FP4 and LineageOS - #345 by onlyJakob. I would’ve based my roomservice.xml for LineageOS 20.0 off that, but I’m confused by the lack of a lineage-20.0 branch in the FairBlobs repo. Do the proprietary blobs for LineageOS 20.0 need to be obtained in a different way?
Did I understand correctly, that after setting up the repository, I need to to create the file .repo/local_manifests/roomservice.xml , then re-run repo sync, and after that I can proceed with breakfast and brunch as described on the LineageOS wiki?
Unfortunately I couldn’t find any instructions about how to build for a device that isn’t yet officially supported by LineageOS, so I’m not sure whether I’m doing it correctly.
The repo with the firmware files has changed. Have a look at my current roomservice.xml. The alternative is to use the ./extract-files.sh script to extract the binary blobs from the stock rom.
I just saw that the FP 4 is now in the supported list from LineageOS 20 (A13). Has anybody tried it?
Does the second camera work?
I would love to try but the FP4 is my only phone and I can’t risk to not be able to use it for a time…
So is it stable, does anything work?
I just saw in the support article for unlocking the bootloader this:
So when I install LineageOS 20 and then I go for some reason back to the original FairphoneOS and when I lock the bootloader, is this a problem? Or how do I have to understand this?
I got stuck in this mess, but used an old tool can’t remember what it was called that set everything up so I could install stock. A tool I used to use for my old Oneplus 6.
