I’m experiencing issues with my FP3’s touchscreen: at the end of the touch input, i.e. when releasing the finger from the screen, the phone seems to read an additional touch-input / movement, which results in additional scrolling / imprecise positioning:
often: minor additional scrolling, imprecise selection (e.g. when cropping images)
sometimes: stronger scrolling (see video)
very seldom: the entire page scrolls wildly in one direction (as if I had it scroll as fast as possible from top to bottom or other way 'round)
This also makes scrolling through web-pages quite unpredictable, because even with always the same kind of touch inputs to push the page up / down, the scrolling is slower or faster intermittently.
Does anybody else experience problems with FP3s touchscreen functionality?
I don’t have this issue. Did you check the touch input visualization in the Developer settings? Maybe that gives a hint on where exactly the ghost input is triggered.
Yep, I filled quite a few test-screens with my touch-inputs, but I couldn’t find anything out of the ordinary - just the many strokes I made, as expected.
So far, Fairphone support has requested additional information from me (results of the touchscreen service test and a video where the finger’s touch input is visible).
Thanks for your reply. Do you also have problems with keyboard sensitivity? Once in a while i get multiples instances of one letter when i press a Key. For exemple : “eeexxxxxeemmppplleeee”
Here is thé Message i have sent to thé support center :
Very often, the tactil screen is is not responding correctly: it is very sensitive, when i touch a key for a letter it writes 3 or 4 of this letter instead of just one, or i can not scroll it press immediately the link under my finger. The becomes unuseful. Please help quickly i m very disappointed with this
I don’t experience the keyboard-issue you described.
(A few times I think the keyboard-swiping was interpreted as “interrupted” (as if I had lifted my finger from the screen to start with a new word, though I didn’t lift it). But then again, it’s really only been a few times, so I don’t mind - and I’m not too sure about the exact behavior in this case anyway. …)
I am traveling and all of a sudden my fairphone 3 has started registering some of my clicks as double or triple clicks. This makes it nearly impossible to use (this message for example took a long time to write, and on most websites it randomly clicks on things). Anyone else experiencing this issue? How can it be solved? I need a quick solution as I’m traveling internationally for a couple of weeks and have no backup…
I’ve been experiencing the same problem for a few days now.
The problem occured very occasionally at first, but it’s been occuring occur more and more lately.
I’ve had black screen issues before. I deassembled/reassembled the screen and it solved my problem. I believe that the problems I’m having now might be linked with that process (maybe some dust on the connectors?).
Anyway I plan on deassembling/cleaning/reassembling the display and connectors once again and see if this solves it. Have you already tried that yourself?
I also sometimes have this issue. I had trouble typing anything yesterday. iitt wwoouulldd aall llookk lliikkee tthhiiss…
Not sure if it is related to charging my phone, or just the touch screen module malfunctioning
I recently noticed this behaviour while the phone was connected to a charger. Things opened when I just wanted to scroll over them. There also was a “nervous” (double) vibration when touching the screen instead of the “usual” one. It reacted “as usual” when I switched off the power.
Maybe I did not really notice this within months becaue I hardly ever use it activley while charging.
I’m currently experiencing the same issue.
Today my FP3 display began blinking. I had the same problem several months ago, and solved it then by disassembling and reassembling the display in order to ensure good contact of the connectors.
The operation was successful for the blinking, but led to this issue of over-sensitivity of the touchscreen.
I re-disassembled the display, carefully cleaned the parts and the contacts with a clean and soft brush. After reassembly, the issue was still here.
It is now impossible to enter PIN code in one time like before. Text entry is also more difficult, and swipe is also difficult and leads often to wrong commands, making the phone hardly usable.
I guess the problem isn’t in the contact. Maybe a component is failing, or some internal setting is maladjusted following first reassembly…
Is there a way to calibrate the touchscreen? Would this help? Or any other suggestion?
I have been having the same issues for a while, apparently at random (over sensitivity: 2 or 3 clicks per touch, random scrolling web pages, impossibility to swipe the keyboard, impossible to unlock by swiping my pattern…)
Reading these posts, I did the test of connecting/disconnecting the charger and it is obvious.
In the screenshot below, typed under Signal, I tried twice to swype the (french) word ‘Absolument’:
first time unplugged: perfect on line 1,
second time plugged with cable into PC: see line 2!
Have done the same test 4 - 5 times, plugged/unplugged: it goes wrong every time it is plugged, works fine when unplugged.
Of course, this happens with a lot of phones.
The “charger” is a switching power supply with several kilohertz switching frequency. If these spikes are not completely filtered out it will have an impact on capacitive touchscreens (and other devices).
You can try to switch to a newer / better charger without worn-out filtering capacitors, for example.
But I would not blame the phone if the charger delivers insufficient filtered current
Thanks for this quick reply, and you are probably right: I had actually plugged the phone via USB onto my PC.
I just tried again with my Samsung charger, and nothing went wrong. Then again with the PC: same problem!
I will keep looking, to check it does not occur in other circumstances, but will stay away from the PC
Still, this is weird. Never occurred with any previous phone?
