FP3+ stuck on spinning blue dots, please help :)
Hello everyone,
Basically my FP3+ gets stuck on the spinning blue dots screen forever.
The only way to turn off the phone is to remove the battery.
And when I insert it again and power on the phone, it gets stuck again with the spinning blue dots (even after a long period without the battery).
I tried using a brand new sim card and it doesn’t work, whatever slot I insert it into.
Also I can’t access the safe mode.
It happened about 2 weeks ago and has been like this since.
I haven’t done anything special before it happened (no installation of apps, etc…).
The charging LED works fine.
The screen itself seems fine because the “fairphone” display appears before going to the spinning blue dots display.
I can access the recovery mode.
I guess I will have to go for a factory reset but since I haven’t done any backup recently, I am a bit reluctant and would prefer another way to fix my problem.
Is there a way to do a backup using a cable through one of the menus in the recovery mode ?
Or, even better, a way to fix it w/o going through factory reset ?
Thanks a lot !
PS: My computer is a macbook pro
To those more in the know: Does this work on the FP3 as well?
Not sure if it will help but have you tried starting in Safe Mode, it may at least confirm it is in the Firmware etc.
Yes I tried and it did not work :frowning_face:
Thanks
With an unlocked bootloader … even easier, you just fastboot boot the TWRP image in fastboot mode.
With a locked bootloader … no chance.
Keeping the power button pressed for about 15 seconds should force a reboot.
Is your bootloader locked or unlocked?
If you don’t know, then it’s probably locked, but you can make sure by booting into fastboot mode (keep Vol - pressed while starting or rebooting the phone), the state is listed there as “Device state”.
In any case, if it’s unlocked, the phone should show a message saying so, every time it’s turned on. I don’t think there’s a way of preventing it on the FP3?
the bootloader it is locked :frowning:
So no way to get my data ? :frowning:
Thanks all
No easy or cheap way :frowning:
I ended up doing a factory reset…
Thanks all for the help.
Best
