Hi, my rear/main Camera isnt working.
Herr are some logs when the camera APP is starting (only ERR)
Thank you for help and if you need more logs, ask me
logcat_02-21-2020_18-49-32.txt.pdf (4.8 KB)
Which kernel are you running?
Does the torch work?
Are you using the GSI overlay?
Kernel is: 4.9.112
Torch dont work.
Yes i using GSI overlay
No, I meant where is that kernel from?
If it’s the stock kernel it’s weird.
If you are using a selfbuilt kernel, it’s quite normal. In that case wifi should also not work.
No its the stock kernel :-/
Ok i got the Camera working.
- Flash the Stock dump (2 times) with the ./flash.sh
- Boot in to both slots (with factory reset)
2.1 update via TWRP to FP3 A.0110 on slot b an make a full reboot. - Install Magisk
- follow the steps on “how-to-flash-a-custom-rom-on-fp3-with-gsi” with err. on
fastboot -w
(Invalid erase-block-size 512: must be a power of 2 and at least 4096. Invalid logical-block-size 512: must be a power of 2 and at least 4096. /usr/lib/android-sdk/platform-tools/mke2fs failed with status 1 mke2fs failed: 1 error: Cannot generate image for userdata
4.1 boot in TWRP to make the factory reset (fail to wipe sd-card, but i think/hope thats normal)
4.2 reboot and on the second reboot the orginal factory reset come up. - after reboot the main camera runs!
install gapps-pico.
