šŸ‡¬šŸ‡§ šŸ‡«šŸ‡· FP3(+) modules & accessories (batteries, cameras, top modules, speakers, covers, rear... regularly updated)
Salut Antoine,
Do you still have a bottom module left and would ship to Austria :austria:?
As a few others before me have already said, I also have trouble charging my phone. I have cleaned the port and tried different chargers but it doesn’t make a difference.
Kind regards, Astrid
Hi Antoine!
I’d be happy to take one of the bottom modules of your hands. It would’ve to be shipped to Germany. I’m a new user, therefore I think sadly I can’t send a direct message.
Kind regards,
OwO
Bonjour,
Est-ce qu’il te reste 1 batterie expĆ©diable Ć  Nantes ou en Sarthe ?
Merci d’avance
Cordialement
Hi! What price can you offer for a FP3 bottom module shipped to Austria?
regards
Bonjour !
Je cherche justement une batterie de rechange pour mon FP3+ . Est-ce qu’il t’en resterait une dispo ? (J’habite Nantes)
JPL
Hi Antoine,
I’m after a bottom module, shipped to UK, because my charging rate suddenly went down to 5% of previous and this looks like the only fix. Do you still have one please?
Thanks,
Andrew
Hello, I’m really interested in buying a bottom module for FP3. Is it still available?
Thank you!
And as I’m there, I would also be interested in having another battery. I live in Marseille so it should be ok for the delivery.
For your information, I’m sorry to announce that I have NO MORE BOTTOM MODULE anymore. I might have one or two coming in the future, but it’s unlikely.
If your bottom module is not working properly, try to clean it with thin tweezers or a needle, to remove the dust. You can also use isopropyl alcohol in spray, or unmount it if you have a torx 5 screwdriver and use isopropyl alcohol on the tip of a cotton stick.
Bonjour Antoine,
Je suis Ć  la recherche d’un Ć©cran pour fp3. En reste-t-il?
Merci!
Jonathan
Bonjour Jonathan,
Malheureusement je n’en ai plus…
Bon courage pour la recherche !
Antoine
Bonjour, j’aimerais acheter un module camĆ©ra FP3 ou FP3+ j’aimerais savoir si les camĆ©ra ont 48mp
UPDATE with:
  • 1 good screen with broken protective glass: 40€
  • 2 bottom modules (1 in good condition for 15€ and 1 not so good but working more or less OK so for free)
  • 1 new battery (made in 2025)
If you’re interested, contact me quickly, they will probably disappear soon!
Hi Antoine, I would be interested in the bottom module (the one in good condition) and the cover. Would you be able to ship to The Netherlands? Cheers, Arno
@Antoine Interested in the screen! Can i remove the broken protective glass and install a new one?
Best, Martin
Sorry,
The screen is already gone…
Bonjour Antoine,
Je suis intƩressƩ par la batterie. Est-elle toujours disponible ?
Cordialement,
RƩmi
Bonjour, le bottom module en bon Ʃtat est-il toujours dispos ? Merci !
Bonjour, malheureusement il ne me reste plus que celui qui a un petit faux contact pour le moment…
Salut, je suis intéressé par le bottom module, même si il a un petit faux contact
