Hey,
I know there are many posts on microphone’s issues, but I realized my problem is a bit different from other (echoes, low volumes…). Two days ago, I started to notice a soft noisy background at the begin of my recorded message in Whatsapp, then the noise (quite a white noise) started to be loud and at the very begin of the message and after 15-30 second it faded out. Now, when I use FP3 for calls nobody can listen my voice. I try to record a message to test and now I listen intermittent noise for 5 second and then silence.
I guess it is something in the contact of the mic, or maybe the mic starts to not work properly.
Should I substitute the module? is that possible?
thank you
best,
R
